Author Topic: Anyone used a XXXX-1 Jamma Board before??  (Read 3595 times)
Matsurigatzu
  • Last login:January 26, 2009, 06:38:03 pm
« on: January 25, 2009, 02:49:42 pm »
I have the XXXX-1 connected and it comes up on screen and its running fine but my controls are not coming on. I cannot even move my joysticks or buttons. Its like they are just off.
Any help??
FrizzleFried
  • Last login:May 30, 2023, 01:14:24 pm
    • Idaho Garagecade
Re: Anyone used a XXXX-1 Jamma Board before??
« Reply #1 on: January 25, 2009, 03:00:18 pm »
You have a ground issue.  The only reason why all controls won't work (aside from a major issue on the PCB) is a ground issue.  I'd bet a $20.00 that's the problem.
Check the ground wire for your buttons.
Matsurigatzu
« Reply #2 on: January 25, 2009, 03:02:55 pm »
I did plug the Motherboard back into the neo geo and the controls work fine. Unplugged it,put it into the Jamma,controls are off.
Still a ground issue you think?
Kevin Mullins
    • Me on Myspace
« Reply #3 on: January 25, 2009, 03:20:55 pm »
I just finished helping a fella figure the same problem out..... his issue was a ground problem.
But you may also want to check any dipswitch settings on the multi board itself which tell the multi board what style cabinet/controls you have.
Like "Upright/1 Controls" or something like that. (match it to your setup)
Matsurigatzu
« Reply #4 on: January 25, 2009, 03:32:10 pm »
where do i find the switches on the jamma board?
Matsurigatzu
« Reply #5 on: January 25, 2009, 03:36:24 pm »
I see 4 switches. When i switch one of them on,do i have to restart the jamma board?
Kevin Mullins
    • Me on Myspace
« Reply #6 on: January 25, 2009, 03:38:51 pm »
Sometimes......
Matsurigatzu
« Reply #7 on: January 25, 2009, 04:30:40 pm »
so i tried restarting.
I dont know which switch does what.
I dont even know how to test for grounding if it so calls for it. Lame. :-)
BobA
  • What Me Worry?
« Reply #8 on: January 25, 2009, 07:11:26 pm »
Maybe post the info on the exact xxxx-1 jamma board that you have so someone can look at the manual for your multi board.
Matsurigatzu
« Reply #9 on: January 25, 2009, 08:39:32 pm »
1069-1 board.
take a look at it.
« Last Edit: January 26, 2009, 05:59:42 pm by Matsurigatzu »
CathalDublin
  • Last login:March 01, 2024, 04:05:23 pm
« Reply #10 on: January 26, 2009, 12:55:31 pm »
Check the manual for that board against your jamma harness
iirc that board has p1 b5/6 and p2 b5/6 which are usually grounds on a standard jamma board
Defender(multiwilliams), SF2CE
Whirlwind, Lethal Weapon 3
FrizzleFried
    • Idaho Garagecade
« Reply #11 on: January 26, 2009, 01:08:03 pm »
Yes...NeoGeo isn't 100% JAMMA and neither is the xxxx-in-1 boards from my recollection.  Ground issue.
FrizzleFried
    • Idaho Garagecade
« Reply #12 on: January 26, 2009, 01:09:01 pm »
1069-1 board.
http://xxx
take a look at it.
You're going to want to remove that link as it's against the rules here.
Matsurigatzu
« Reply #13 on: January 26, 2009, 06:00:06 pm »
the only reason why i posted is because that guy wanted to know what i was looking at. my bad
CathalDublin
« Reply #14 on: January 26, 2009, 09:01:30 pm »
A sheet should come with that board with the pinouts, just trace the wires on your harness and see whats wrong
