Main > Main Forum
Anyone used a XXXX-1 Jamma Board before??
CathalDublin:
Check the manual for that board against your jamma harness
iirc that board has p1 b5/6 and p2 b5/6 which are usually grounds on a standard jamma board
FrizzleFried:
--- Quote from: Matsurigatzu on January 25, 2009, 03:02:55 pm ---I did plug the Motherboard back into the neo geo and the controls work fine. Unplugged it,put it into the Jamma,controls are off.
Still a ground issue you think?
Yes...NeoGeo isn't 100% JAMMA and neither is the xxxx-in-1 boards from my recollection. Ground issue.
FrizzleFried:
--- Quote from: Matsurigatzu on January 25, 2009, 08:39:32 pm ---1069-1 board.
http://xxx
take a look at it.
You're going to want to remove that link as it's against the rules here.
Matsurigatzu:
the only reason why i posted is because that guy wanted to know what i was looking at. my bad
CathalDublin:
A sheet should come with that board with the pinouts, just trace the wires on your harness and see whats wrong
