Poll
What would you say is Better?
Viynl
Paint
Other
Author Topic: Vinyl Vs. Paint  (Read 1179 times)
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
Vinyl Vs. Paint
« on: January 23, 2009, 03:34:37 pm »
Hello i wanted to see what is better to use on a cab please tell me the pro's and cons
thatitalian
  • The Revolution Is Coming...
Re: Vinyl Vs. Paint
« Reply #1 on: January 23, 2009, 03:40:29 pm »
Laminate or Formica
Ginsu Victim
  • Comanche, OK -- USA
Re: Vinyl Vs. Paint
« Reply #2 on: January 23, 2009, 03:42:42 pm »
lead paint ;D
Be sure to taste the chips!
wooowman93
Re: Vinyl Vs. Paint
« Reply #3 on: January 23, 2009, 03:47:39 pm »
Laminate or Formica
laminate
and is it ok if i use your marvel arcade marquee
thatitalian
Re: Vinyl Vs. Paint
« Reply #4 on: January 23, 2009, 04:06:41 pm »
lead paint ;D
DUDE!!! :laugh2:
Of course bud! That's what it's there for!
I think I received a PM from you ages ago but your file is corrupt. Was it a CP?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Vinyl Vs. Paint
« Reply #5 on: January 23, 2009, 04:07:55 pm »
Did you guys just add two new categories ?
From my POV, it depends on the cabinet and on how lazy/motivated you are.
Rolled vinyl adhensive, like Happ offers:
is nice (I use it for CPs), but you need to clean the underlying surface up pretty decently first.
Same deal with paint and a slightly lesser deal with laminates/formica (although there you need a router to cut things).
BUT, since you are a student trying to save money, presumably without many tools, the obvious answer for what you should choose is paint.
Working: Not Enough
Projects: Too Many
Progress: None
wooowman93
Re: Vinyl Vs. Paint
« Reply #6 on: January 23, 2009, 05:27:13 pm »
lead paint ;D
i tasted the lead paint about a 1/4 a tub it was kinda salty
is that good
my head also started to hurt a bit after
« Last Edit: January 23, 2009, 05:30:10 pm by wooowman93 »
ivwshane
  • Last login:December 24, 2022, 09:35:21 pm
    • My first mame cab! (WIP)
Re: Vinyl Vs. Paint
« Reply #7 on: January 24, 2009, 12:55:43 am »
If you can afford and find it I think laminate is the best way to go!
It's extremely durable, it looks great, and it really adds that extra touch to a cab.
Unfortunately it's hard to find (usually you have to special order it) and if you do find it it's pretty expensive (I was quoted $80 per sheet and would have need three sheets).
