Author Topic: Donkey Kong Info (I'm looking for the CP Dimensions)  (Read 1089 times)
  • Last login:Today at 07:54:28 pm
« on: January 22, 2009, 11:41:44 am »
OK, it's too cold right now to work outside in the garage (and it will be for several more months) but I wanted to try and get a jump start on my 2009 project - a Donkey Kong restoration - by cleaning and restoring the coin door.  I have never done something like this before so I'm open to any and all suggestions (including  getting someone else to do it!).  These things are semi-rare from what I understand because there isn't anyone making reproduction Nintendo coin doors (that I know of).
Mine is in really good shape (I think) since there are no dents and a security bar was never installed.  I have seen Peale's very helpful tutorial HERE and I'm thinking about giving it a shot on this thing.  Obviously, I want it to look as "factory" as possible when I'm finished.
I've attached some pics of where I'm starting from.  Any tips, suggestions or things I should be aware of before starting?
« Last Edit: January 27, 2009, 10:03:33 am by javeryh »
Level42
Re: Restoring a DK Coin Door?? [PICS]
« Reply #1 on: January 22, 2009, 04:19:41 pm »
Don't want to discourage you but it's a PITA to sand the Nintendo doors. Lots of nicks and places where you can't seem to reach.....
But be sure to sand it completely bare. I had mine powdercoated. I did a poor job on getting the dents out (as much as possible) and sanded as good as I could. The guy doing the powdercoating did some minor final sandblasting. All in all it looks OK.
If I were you I'd buy new frontplates for the coin-mechs at Asahi Seiko. Saves you a LOT of hassle, and the only wat to get a completely new and original look. Maybe the coin returns, push button etc are also worth getting.
« Reply #2 on: January 22, 2009, 05:52:27 pm »
Thanks.  I am leaning towards buying the front plates from Asahi Seiko (even at $40) to get it looking factory fresh.  I'm going to try and clean them up myself maybe as a placeholder and then spring for them when I get some extra money.  Do you think I should try a chemical method of removing the paint?  I guess I'll look into powdercoating but I have no idea where to begin looking for someone to do that for me.
csa3d
  • Will game for food
    • Galaxian Mame Conversion
« Reply #3 on: January 22, 2009, 06:47:52 pm »
Not sure if it will help at all or not, but here's how I restored my midway door.  I had limited success with the chemical approach, and opted for using a wire wheel.  Much faster, and far less mess.  I'd get a big wire wheel and a small one like the dremmel chuck I used to get into those hard to reach places.
Anxious to see how yours goes!
-csa
jimkirk
  • Last login:October 27, 2013, 01:24:15 am
  • Ahead warp factor 5 Mr. Sulu.
« Reply #4 on: January 22, 2009, 10:21:54 pm »
I bought the faceplates from asahi seiko and now my mechs look factory new.
You don't need to get new push buttons or coin holders,just polish them.
I know who Phet is and many of you do not.
« Reply #5 on: January 27, 2009, 10:03:13 am »
Great info for the coin door.  Maybe I'll give it a shot myself.  I hate sanding but whatever...
OK, some more Donkey Kong questions... maybe I'll just post them here since I'm bound to have a lot of them as I go.  Does anyone have the plans for a Donkey Kong CP?  My cab did not come with one and I need to know the dimensions in order to cut out the panel.
Thanks!!   :cheers:
Donkey_Kong
    • CNC Machines
Re: Donkey Kong Info (I'm looking for the CP Dimensions)
« Reply #6 on: January 27, 2009, 10:38:17 am »
« Reply #7 on: January 27, 2009, 10:57:22 am »
Full cabinet plans from jakobud
http://www.jakobud.com/cabinetPlans/donkeykong_jpg.zip
Thanks for the link but the CP dimensions are not included.  I know the rough size of the rectangle (56.6cm x 21cm?) but I don't know where to drill the button holes and where to mount the joystick.
Bender
« Reply #8 on: January 27, 2009, 12:01:02 pm »
I re-did mine and still have the original, its a little beat up but you can get all the info you need from it I think
I'll send it to you if you promise to send it back
« Reply #9 on: January 27, 2009, 12:51:43 pm »
Wow sweet!  I promise!
PMed.
