Author Topic: j pac or i pac  (Read 1884 times)
jessybr
  • Last login:December 25, 2016, 05:54:07 am
j pac or i pac
« on: January 15, 2009, 10:09:56 am »
hello everybody
i have got a universel cab with jamma connector and the monitor is broken
i have a j pac  is it possible to connect the jamma connetor
and use a monitor from the computer .
or do i have to buy an i pac
all tips are welkom
greeting from holland
fa001
  • Last login:November 14, 2023, 11:17:08 am
Re: j pac or i pac
« Reply #1 on: January 15, 2009, 11:36:19 am »
The jpac goes the other way. It takes a PC video out to an arcade monitor video in. Not what it sounds like you are doing.
The ipac does nothing with video.
Not sure what board you are using but if it is standard jamma then you need a cga to vga converter to run a PC monitor.
jessybr
Re: j pac or i pac
« Reply #2 on: January 15, 2009, 12:22:48 pm »
hi
i just want to use the j pac
and from the pc direct a monitor and not from the j pac
Ginsu Victim
  • Comanche, OK -- USA
Re: j pac or i pac
« Reply #3 on: January 15, 2009, 12:26:27 pm »
Shouldn't be a problem. Use the jpac for the jamma connector controls and run the PC monitor from your computer.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: j pac or i pac
« Reply #4 on: January 15, 2009, 12:43:16 pm »
+1
Working: Not Enough
Projects: Too Many
Progress: None
jessybr
Re: j pac or i pac
« Reply #5 on: January 18, 2009, 05:42:07 am »
hey everybody i am going to use the j pac
yust bought it for 30 euro
thankd for the info
