Author Topic: Losing my mind!!!  (Read 1200 times)
thatitalian
  • The Revolution Is Coming...
Losing my mind!!!
« on: January 14, 2009, 09:12:52 am »
I am trying to get these damn dimensions perfect before I do any cutting and, well, I am going ---smurfing--- crazy! :angry:
I have all the dimensions but what I really need are all the angles to cut the pieces at in order for them to sit flush against each other.
Could anyone help out in anyway? I ma not even sure if there is a program (maybe autocad) that would tell you what size the pieces need to be, at what angle you have to cut them at including the extra length needed if you are cutting an angle "outside" the width it states.
For example: I have a piece that is 250mm in length, 12mm thick and I need a 45 deg cut facing OUTWARDS on each side. Geometry would tell me that I need a piece that is 274mm in length and then trim that inwards 45 degs in order to get the 250mm length that I need. Does that make any sense? :banghead: :banghead: :banghead:
Franco has helped me out constantly and to be honest I feel a bit bad asking him again because he is trying to finish his juke.
If anyone is able to use sketch-up to draw up a model I would also appreciate it SO MUCH before I actually jump out of the building I am in!!!
I can provide the measurements and directions.
Thanks guys!
  • Last login:Today at 08:03:14 pm
Re: Losing my mind!!!
« Reply #1 on: January 14, 2009, 09:25:52 am »
Bender
« Reply #2 on: January 14, 2009, 09:34:51 am »
I do pretty detailed skech-up mock ups but the for tuning your talking about I do in the woodshop. There are always little things that need to be adjusted.
To use your example for instance I'd measure and then draw the 45 on with a carpenters square, then line it up with the blade. nothing like physically seeing it to make me feel confident about the placement IMHO
shardian
« Reply #3 on: January 14, 2009, 09:42:06 am »
Click here
That is awesome. I can't wait to use that on someone.
thatitalian
« Reply #4 on: January 14, 2009, 09:45:47 am »
Click here
HAHAHAHAHA! :laugh2: :laugh2: :laugh2:
That is quite good, where the hell do you get these things! LoL.
That is exactly what I have been doing for each one hence the losing my mind!
Franco B
« Reply #5 on: January 14, 2009, 09:48:55 am »
Dude, seriously, you only have to ask!  :)
I'm at home now and will be about most of the evening. Hit me up on MSN or PM me.
Edit:
Click here
Heh! Just checked the link, can't wait to use that either. Can see it getting used a fair bit  >:D
« Last Edit: January 14, 2009, 09:50:28 am by Franco B »
« Reply #6 on: January 14, 2009, 09:56:23 am »
That site is awesome...  I love using it, lol.
thatitalian
« Reply #7 on: January 14, 2009, 10:04:17 am »
Edit:
Click here
Cheers Bud! At work now but will PM you.
As for a sketch-up model, still open to offers  >:D
Just in case:Click here
Bender
« Reply #8 on: January 14, 2009, 10:12:53 am »
Damn that is awesome!
Franco B
« Reply #9 on: January 14, 2009, 10:31:36 am »
I really need to have a play with Sketch-up!
I can do all your plans for you in CAD though bud and create a cutting list/drawings for you.
thatitalian
« Reply #10 on: January 14, 2009, 10:42:12 am »
Stress level has dramatically decreased.... ahhhhhhh :woot
Thanks Franco, YET AGAIN!
Is there anyway to add this to my list of smileys so I don't have to keep typing "Thanks Franco, YET AGAIN!"? ;D
