Author Topic: Project : C-MACC'S 2 - (update - Subzero Cooling Phase change -50 c)  (Read 42033 times)
mayhem
  • Last login:July 11, 2016, 03:37:04 am
  • http://cmaccs.com/
    • C-Macc's
Re: Project : C-MACC'S 2 - sponsored by ultimarc + Gameex
« Reply #80 on: April 20, 2009, 04:29:21 pm »
you must have a steady hand and alot of patience..those look really good.
Thks and not really hehe. Its quite calming ..
a bit more test etching. I don't think the Bumps on the egg worked out very well but hay ho its all about learning. Im now going to attempt to do the aliens allot smaller now as the sizes i have done are quite large and my Cp doest require them to be that big. So ill now have a go at doing them 1/2 the size while seeing if i can still retain the detail. If that works we can see how things go from there.
Pics below of the face hugger coming out of a egg. This took about 25 min to make. Not to happy with it though. I think the best design so far is the second alien.
Gatsu
« Reply #81 on: April 20, 2009, 08:03:02 pm »
dude...that face huggers vagina/penis thing is lookin at me.  :o
mayhem
    • C-Macc's
« Reply #82 on: April 20, 2009, 09:50:33 pm »
lol Giger's Alien's do have the Phallic symbols written all over them ... Might be why they were so popular to people they just didn't know what they were looking at lol ...
To be real honest i think most art work esp horror wise is quite Phallic in one way or another very much like most things in this world but i all so believe it to be what some don't see others do .
All so saying that it might explain why my lass said to me "You cannot stick that on it" and me being clueless couldn't understand what she was going on about ... All the more reason to stick it in now hahaha ...
Namco
  • Last login:November 14, 2025, 12:56:14 am
    • Freddo Mame Project
« Reply #83 on: April 21, 2009, 11:26:49 am »
Hello bud, great build so far. Can't wait until it's done. I couldn't help but notice that you have plans for an Xbox 360 in the cabinet. Is there any way to interface the Ultrastik 360s to the Xbox's analog sticks... and have it actually behave in analog more? Or I imagine you are simply going to use wireless controllers for Xbox 360 control?
mayhem
    • C-Macc's
« Reply #84 on: April 21, 2009, 12:07:07 pm »
Thank you.
Ive only tested them on the ps3 and they worked. I have extra pads for the 360 so haven't really tested them out on that yet. I might work on that later on once i get to that point. The sticks are programmable so i presume they should be able work all though i could be wrong.
You could fire a email off to andy at ultimarc.com and ask him if it works. he would be the best person to ask ;) .
« Last Edit: April 21, 2009, 12:10:33 pm by mayhem »
mayhem
    • C-Macc's
« Reply #85 on: April 24, 2009, 06:54:01 am »
This is a very fast dirty test to check out lighting on the alien designs. Just to see what it would look like. I can see the 3mm led's really are not enough to light up a full panel so ill have to try out some 5mm led's next to see what effect they will have.
The 3mm btw have been drilled into the plastic but like all things that come from Hong Kong only 1/2 of them work lol ....
sayitaintjonas
  • Last login:June 27, 2019, 10:56:55 am
« Reply #86 on: April 24, 2009, 08:55:18 am »
I've picked up a lot of leds from Hong Kong and they usually work out pretty well, although I've a couple that  blow out as soon as I've powered them up.
I really like where you're going with the etched cp.  :applaud:
mayhem
    • C-Macc's
« Reply #87 on: April 24, 2009, 11:38:01 am »
It might be my suppler being so totally Wrapp (replace the w with a c) lol ......
Im going to order some strip lighting (blue) for it. There is 30 Bright Led's on a strip that is bendable so it will show up the effect better. I've just trashed every thing else for now and im awaiting my dammed printer ink (god some suppliers of stuff are just lazy) so i can do some more designs and see how they look.
I might do what i did with my old xbox and give the CP a little more umph to it.
to show what i mean here is a old vid of my old xbox ...
[youtube]SWbj_ixZ_5M[/youtube]
I might do this around the CP. Its been a while since i did it but im sure i can do it again.
mayhem
    • C-Macc's
« Reply #88 on: April 25, 2009, 09:43:12 am »
Must admit its not easy this time I'm trying to learn to feather touch and see how it comes out. When doing it lightly you hardly see the work your doing (or it could be because i have bad light) any way i tried doing this with the lowest dremmel points ...
After a second look i then re did the head with a larger point to make it stick out more. I think its a fine line between what looks good and what doesn't lol ...
<img src="http://i380.photobucket.com/albums/oo244/mlwood2008/etching/010-1.jpg">
Then added a CCFL tube just to test it out for idea's ... Its so dammed hard taking good photos of this stuff lol ...
mayhem
    • C-Macc's
Re: Project : C-MACC'S 2 - "Come play with me" !!!!!
« Reply #89 on: April 27, 2009, 08:35:03 pm »
Working on cab etchings now as i type this (just having a rest)
These are quite close up as the image is only approx 2" in hight and about 3.5" in width. So it looks a little wobbly but then again i haven't cleaned it up yet neither.
Oky first alien finished on the CP ...
Need to do more work but you'll get the jist of what im up to ...
mayhem
    • C-Macc's
Re: Project : C-MACC'S 2 - Alien Etching On the CP
« Reply #90 on: April 27, 2009, 10:47:54 pm »
Nearly finished second one. Hands aces so ive stopped but here's the pics any way ....
thatpurplestuff
  • Last login:May 10, 2025, 02:37:15 pm
« Reply #91 on: April 27, 2009, 10:49:33 pm »
These are turning out fantastic.  Really looking forward to seeing everything put together and lit up!
mayhem
    • C-Macc's
« Reply #92 on: April 28, 2009, 12:02:01 am »
My lighting is rubbish atm , but to give you a idea with some bad red cold cathode tubes here you. they don't relay give it enough effect and it took 50 pics before i got a few to look oky ...
Ill be getting some much strong Leds later on to test it out better.
this shot came out really wired but looks unreal ...
mayhem
    • C-Macc's
« Reply #93 on: April 29, 2009, 05:11:11 pm »
Here are a few pics inc back of my head caught in the act lol ...
What im doing is.
1) wiring
2) Setting up led lights on the buttons
3) setting up joysticks and digital out puts
4) wiring up the second LCD and touch screen
5) wiring up / leds and roller ball
6) sequencing the lights
7) testing it all works
The Cp is not lighted on the perspex just yet ill do that later on i think ive had enough of leds over the last few days.
last but not least this Cp weighs a tonne lol ...
mayhem
    • C-Macc's
Re: Project : C-MACC'S 2 - Light show !!! Video just standard rubbish .....
« Reply #94 on: April 29, 2009, 09:47:43 pm »
here you go ...
[youtube]InIPew47nGg[/youtube]
sayitaintjonas
« Reply #95 on: April 30, 2009, 07:27:58 am »
 8)
Awesome
mayhem
    • C-Macc's
Holy cow ive been nominated on Bi Tech for mod of the moth. Wow that is truly a awesome achievement for me.
Please vote if you think it deserves a win ..
View here ->
http://www.bit-tech.net/modding/mod-of-the-month/2009/04/30/mod-of-the-month-april-2009/1
Vote here ->
http://forums.bit-tech.net/showthread.php?t=167580
Thank you
mayhem
    • C-Macc's
Re: Project : C-MACC'S 2 - Bi Tech Mod of the month nominee
« Reply #97 on: May 01, 2009, 08:51:46 pm »
Oky last 48 hours i been hammering away at this thing to get the Cp in a near finished state. Tomorrow ill start work on the back box. Here are some more pics and Vid of the Cp working. some one posted saying the music to the Vid (not on this forum) was set up and it wasn't in sync thinking that the Leds are all pre programmed and not to music sooo ... ive posted a new vid to to null and void that point.
All so updated some pics of the Cp showing the lighting on the cp with the perspex now lit up. that all so goes to music but i forget to turn it on in the vid. You can see the lighting much better in life than what a cheap £50 camera can record but hay that's life i cannot afford to do this and by a camera at the same time.
Some of us are currently out of work hehe ...
[youtube]http://www.youtube.com/watch?v=GQDHs-wy6cI[/youtube]
p.s thks for the heads up tom on linking vids.
i will now start working on the back box for the system so there wont be many updates now as that is going to take all my time up....
mayhem
    • C-Macc's
« Reply #98 on: May 05, 2009, 12:17:33 pm »
Small update's as such.
First off you can see the Cp is being tested and the best way to test give it to the family and let them lose .... lol. mrs pac man getting tested on the 4 way.
My lass's score has increased so it defiantly working with the dedicated 4 way joy stick she could never get onto more than level 6. she managed level 15 ... so she's happy (she wont be if she see's these pics though lol)
Some pics of the back box being worked on. Ive drilled 3 holes for the 120mm fans to cool the Consoles down there will be another 3 on the other side to. one thing i learnt with c-macc's 1 was that consoles just create if not more heat than a pc and enclosing them forces the temperature to abnormal levels if not ventilated correctly so we have sold that problem before it even arises.
The reason why the holes look more forward is there is a 1" false wall to hide the cabling to the system and i need the holes to give good air flow hence they are in the middle of the shelf now the back box.
mayhem
    • C-Macc's
« Reply #99 on: May 07, 2009, 02:54:31 pm »
This is called rushing to meet demands !!!!!!!
No back box fitted just yet nothing i can do to get that ready in time ...
32" Samsung TV fitted 1/2 complete assembly ...
Blew Up PC while rushing around and dropped screw driver on a live mother board haha. Not a problem though stolen one of the kids for the moment.
Cables from TV to System hidden for now with twist ties later on this will be done with plastic square tubing.
At least you get the idea were its heading ....
mayhem
    • C-Macc's
« Reply #100 on: May 08, 2009, 02:53:15 pm »
First we start with karaoke .. Sun fly disks playing ->
Then we have Album Player with Mini Lyric's running on main screen and Album Player o the touch screen.
Then we have Mame running ...
And then kids testing out the system ...
I've still not finished the back box due to money limitations and having to get new hardware. I will do that later on when i can afford to buy the electronics that i need to fit. Im all so going to work up a 2 player none Touch screen CP without the keyboard just to show how you can change the system to your own needs of the system. This will be 2 x thinner than the current cp. All so i can show how it only takes 1 min to swap out the control panels.
The possibilities are endless to what i can do to this frame work.. But the question would be "Would you have one of these in your home ?"
mayhem
    • C-Macc's
Re: Project : C-MACC'S 2 - Complete Muti Arcade Computer Console System
« Reply #101 on: May 15, 2009, 11:17:29 pm »
Well getting back up to speed my leds arrived this morning.
hehe i knew they were small but forgot how small they were.
I have ordered 500 SMD leds and here is the pic's and yes these are for C-Macc's.
The pic is just show show you how small my Smd's really are
All so Get various other leds 5mm / 3mm  to try out some idea's that ill be attempting for the control panel. If what i have in mind works Then Its going to be a rite beauty.
All so some other pics of some of the items i have now.
If any one knows about xbox modding they will know what this is. Oh and no its not going into a xbox its going into my cp for some thing really nice.
Im still awaiting more of my orders to come before i proceed.
Dont you just hate it when ppl just plant photos online and then don't tell you what they are up to lol ...
Been having a Good think about the way im going to be setting up my leds and chaser set up.
Any way i have been thinking after looking around every one seems to use simple  1 colour set up were as i can go a bit mental and throw in a RGB led and make it look totally different. The only problem would be, it could possible look to much like Christmas has come early.
This would be the way i would be doing each string of RGB leds as a diagram but dont know if i should proceed this way.
There would be 10 of these strings set up ... Hmm should i stick to maybe just red or should i go mental and do a full RGB spread ?
What do you people think ......
mayhem
    • C-Macc's
« Reply #102 on: May 16, 2009, 07:41:43 am »
Soldering Tools
To do a good job and not bodge it to much there are some very cheap and inexpensive tools you can use in the aid of soldering. Many people just use their hands which is quite fine but there are some serious repercussions with this method in the least the ability to burn yourself very seriously.
So here is a list of just some of the tools that we can use in out arsenal.
Picks , brushes and Pointers.
These are excellent for removing and cleaning up joints and help in the movement of small SMD's. some people use their fingers as well but to be honest is not a good idea. when you use you fingers you end up transfusing grease form you hands to the electrical components which in turn can cause many problems. These cost about £3 for a set at the cheap end like mine or you can go for the more expensive set for about £10.
Tweezers
If you didn't know there are many varieties of tweezers out there and the most common is the version you pick up from you local store or chemist that are used to pull eyebrows or spelks out of people skin these are no good at all for soldering there just to clumsy. What you need is a decent pair with nice pointed tips or even the type that doctors use with a bend in them. The ones pictured below are clock makers tweezers and they have very very fine tips on them which is perfect for moving and handling SMD's and LED's. These Clock Makers tweezers cost about £4.50 for a set but you can pay anything up to £10 for a small set or even just one.
Clock makers , Jewellers eye glass
These come in various forms from x5 right up to x25 times. I personally have a x10 one which is excellent for checking soldering on SMD's and legs on chips. You can easily pick out bridges and mistakes with these. Not everyone uses them but since it only costs about £2.50 for cheap one it is a worthwhile investment in the long term.
Soldering Braid
Now when you make mistakes this stuff is unbelievably handy stuff to have around. Braid is used to Mop up excess solder and can help in the cleaning of mistakes and bridges that you may have created. It comes in various widths and lengths. However a little warning the really cheap stuff is rubbish and makes more of a mess than anything else. It only costs a few pence more for decent stuff. It should cost no more than that £1 to £5 depending on the length you buy.
Helping Hands
One of the best tools ever created for doing soldering. These little babies can hold you PCB steady for you while you work. Not only do they hold them they all have a nice medium magnify glass to help and aid in the LED's and SMD's onto you PCB or Bread board. I cannot stress how useful they are. If you only going to buy one tool then get one of these you'll never regret it. They cost  from £4.50 to £10 and come in various forms.
Hobby Knife , Scalpel
Again another handy tool to have as these can be used for slicing and for many things such as cutting PCB lines or bread board. Again they do not cost much from £1 to £10 depending on what type you get.
Soldering station or Soldering iron.
There are many different types of soldering irons from gas driven ones to cold ones that only heat up once it makes contact with the Solder. I will only be concentrating on the normal electric soldering iron's as the other two are useless for what we need.
Now i own 2 different types. The first one is a plain old 18 Watt standard off the shelf simple soldering iron. It has been in  use for many years and is what i used to mod and fix consoles and various other things. It has been a very handy tool and was perfect for my normal soldering needs. The only problem with it is that 18 watt is just some times to much or to little. These cost about £10 to £18
Pic below and yes it needs cleaning.
Next we have my best friend my soldering station. Now this little beast has a variable heat source for controlling the amount of wattage that the soldering iron gets as well as a Heat pen for flow soldering and all so adjustable voltage so i can test out my project's without using other equipment. It may look expansive but only cost £75.00
Now if your going to get into soldering components a lot i suggest getting a work station as its benefits far outweigh any soldering iron and they needn't be expensive. the one above all so came with leads to connect many different mobile phones so that you could power them up and all so crocodile clips and more.
Solder
There are many different types of solder so you need to chose one that suits your needs. If working with SMD's hand doing by a soldering iron get the thinnest you can or solder paste. If anything else you can use any standard stuff. Like normal though the more you pay the better the solder.
De soldering Pump.
I prefer Solder wick to this method but it you make a big blob this can help the start of the cleanup operation. So again its one of those thing's that is just good to have just in case you need it.
Flux
Now flux is quite important when working with SMD's as it help the solder to stick to the SMD quite well. I user a Flux pen on all my work and it has a shelf life of around 2 years. I think i may have passed that now so i need to order some more.
Fibre Pen
Fibre pens are really handy to have esp when working in modding and needing to get access to a track that is under a thin layer of protective coating. I have gone through about 20+ refill with this thing so it gets hammered allot.  Its all so excellent for cleaning certain areas. Just don't over do it as this tuff can rip though protective layers like mad.
Thin nosed pliers and wire cutters.
Needless to say what there are for.
« Last Edit: May 16, 2009, 01:13:20 pm by mayhem »
mayhem
    • C-Macc's
« Reply #103 on: May 16, 2009, 03:14:06 pm »
Oky here is how to solder (This is not perfect but will do for now)
The parts in the pic below are what im am going to solder to a bread board. The reason for these parts is i need to see how bright the leds are as i need to use the correct Leds before i start making my string of leds for my project. On my work top there is all so a SMD (see if you can find it lol) ...
Parts ->
Now First you put each LED into where you would like them to go. normally people don't bend them but since it's the only way i can hold them into place i do bend them. The longer leg By the way is the positive and the shorter leg is  the negative.
Led  on the bread board ->
Next you need to solder it in. To do this depending on if you are left handed or right handed approach your leg with the solder coming from the left side and the soldering iron from the right side Like the Diagram below. Heat up the leg with the soldering iron on the right and then apply the solder on the left. If done correctly the solder will flow around the base of the leg and nip the leg into place as it cools.
Now the solder did not flow all the way around the leg so i quickly touched it up again just to make sure
Do this all the way along. The black bits on the solder is because i never bothered cleaning my soldering tip (cos im a lazy bugger). Then fit the rest of the components and solder in again.
Here you can see the top side nearly complete. The underside you'll notice some scoring this is were i cut the strip board to allow the resistors to work correctly.
A quick test to check out the LED's to my surprise the top two 5mm leds are supposed be different MCD's (how much light they produce) and after looking carefully they are the same. So when on ebay don't believe everything you read ...
Next ill show you how i do my SMD's once i can find it lol.. All so a note to my self get Practising .... I could clean up the solder with the Solder mod but im not going to as it is a waste and this is just me testing out my led's.
mayhem
    • C-Macc's
« Reply #104 on: May 16, 2009, 05:08:08 pm »
wel last but not least and trust me we took over 50 pics and 1 turned out lol. To solder the SMD the best way is to put a dab of solder down and then using a set of tweezers move the SMD into place and then heat up the solder. Then once it is in place Put a dab of solder on the other side still holding it down with tweezers.
here is a Drawing of how to do it because my camera is just not good enough to show the smd being soldered into place sorry.
Pic of the SMD to be soldered !!!!
Trying my hardest to get a pic in progress
So here is a diagram instead ->
Then here is a pic of it being tested ...
When doing this type of soldering its best to use a Eye magnify glass with a min of x10 so you can see what you are doing.
Hope this helps people.
mayhem
    • C-Macc's
« Reply #105 on: May 20, 2009, 02:17:56 pm »
this is the plan of attack for my 5 Led spectrum analyser / strobe / chaser ...
I think how ever the spectrum analyser  section may not work ...
This would need to be repeated 2x on each string that i create ...
Im going with 5mm Leds for the RGB set up and have 50x of them. What ill try and do is create a Star sign around the roller ball.
For any one interested in the roller ball that was going to be Laser etched in 3d . It melted in the centre lol ..... we though that might happen and as far as we knew has never been tried before .. now we know why !!!! We still have two left to play with though so attempts are going to be made on them.
Been having a long hard think about lighting on this mod and this is a second PCB possible design that i have come up with ....
Why hasn't any one come up with these ideas before for custom lighting PCB's ....
Ive adapted my design to general purpose so that basic you can custom light with strobe, chaser, sequence, VU meter and so many more and it can all be easily done. You can buy boring old single lighting but with this you can do what ever the hell you like easily ....
Now were the hell can i get these prototype cheaply !!!! If we could get them down to say £1.50 to £2.50 per PCB i think it would sell quite well. Imagine how much time this would save...
guinea13
  • Last login:January 10, 2010, 11:55:53 pm
« Reply #106 on: June 04, 2009, 10:28:18 pm »
I had purchased a similar lilliput (an 8" version).  I got it connected up.  I also purchased game ex and got that working but can't seem to get any info on the touch screen when playing the game.  Also,  Is there a seperate juke box software?
Did you build an app?  is there something special you have to do?  Could you give me some hints or advice or an app that would help.
!) Juke Box mode. Touch the screen and play that tune
2) Extra info during mame - Screen shots , Marquee, Cabs, ect ect
3) Extra info for games
4) System Info
5) Touch screen games
6) Nitendo DS ;) ..........
The list is endless. Oh to have some thing not many other have ... lol
[youtube]http://www.youtube.com/watch?v=61QsSA5t7D8[/youtube]
P.s This is why game ex rocks ............
mayhem
    • C-Macc's
« Reply #107 on: June 17, 2009, 10:37:05 pm »
been a while since ive posted so here a few updates.
The reason its been a while is all about money but ive slowly been putting together my water cooling kit. as most may know a decent water cooling kit is quite expensive  here are a few pics of just some of the kit.
then here is a pic of the test loop to check for any water leakage ect ect ..
http://i380.photobucket.com/albums/oo244/mlwood2008/009-6.jpg
Allso been making some LED lights for the cp here are the build pics.
I managed to get a couple of New boards there not as good as what i wanted but they will do the tick.
First we have the basic components layed out
The we solder them in and here are a few pics along the way ->
That's 1 UV meter ready. Both have been built but ill be fitting them another time as im out of cash for the moment lol and need to get some other parts.
mayhem
    • C-Macc's
« Reply #108 on: June 18, 2009, 11:45:54 am »
While im still awaiting to be able to afford more parts ive been working on some thing else ...
early concept designs just for you to look at ...
mayhem
    • C-Macc's
« Reply #109 on: June 22, 2009, 05:56:52 am »
I have still been playing slowly .. getting stable only settings and so far im up to a 57.9% over clock stable. That's  3.789 ghz Over clock Testing over 4 hours.
My max temps are 45c on 95% load wich i may consider quite good witch such a large over clock only on a duel rad and there is no NB/SB water cooling just on air with only the CPU being water cooled.
It would be interesting to see the results on a 3 x 120mm rad but since i don't have one it isn't going to happen any time soon.
[youtube]http://www.youtube.com/watch?v=5dvxdFINsLA[/youtube]
Ive done a video and will upload now of it running Street Fighter IV @ the rated over clock of 3.81 Ghz.
mayhem
    • C-Macc's
« Reply #110 on: July 07, 2009, 05:24:02 pm »
been working on the arcade pc a bit more still more water loops to add in but its getting there.
going to have to re do the back box though lol to fit it all in.
mayhem
    • C-Macc's
« Reply #111 on: July 31, 2009, 03:08:34 am »
well some news for you guys. I been humming and haring over the last few months on some thing ive been wanting to do for a long time. (8 years)
I ve taken the plunge and am picking up a Phase unit in 2 weeks time. C-Macc's 2 is going SUB zero cooling.
Im fitting out c-macc's 2 with a -50c Phase system. So the PC can be over clocked to chronic speeds. I never seen any one build one of these units into a arcade system and i think it may be the first how ever i could be wrong.
So if things go right you going to see a first.
Ill post up more details and pics once i have it in my hands so you can keep an eye out for some thing different.
How ever this will take time so don't expect to much info to fast.
Franco B
« Reply #112 on: July 31, 2009, 03:48:10 am »
mayhem
    • C-Macc's
« Reply #113 on: July 31, 2009, 03:31:31 pm »
this is what im getting ->
BASS!
  • Just have fun.
« Reply #114 on: July 31, 2009, 05:07:25 pm »
Wow, now that is some ---steaming pile of meadow muffin---.
« Reply #115 on: July 31, 2009, 05:56:55 pm »
With the risk of sounding rude, what is the point of this?  Does it somehow improve computer performance?  Is there a reason you are going through all of this trouble (and expense)?  It looks way cool though...
:dizzy:
mayhem
    • C-Macc's
« Reply #116 on: July 31, 2009, 06:44:01 pm »
well atm i can over clock my E5200 from 2.6ghz to 4.66 Ghz stable.
Using this i should in they be able to hit between 5 to 5.2 Ghz stable. (this being more than a 100% over clock on a cheap £48 cpu) meaning im more than doubling the speed of the pc CPU.
Don't forget MAME is CPU dependant and this will give me a larger ratio of games being able to run at full speed on a 32" tft screen.
Throw this together with my 4 x F1's in raid the boot up times and loading times will be to say the least fast.
Not only that ... It will be a first ... (hold's big heavy brass balls in hand) ;).
Im taking my skill's and implementing my knowledge of over clocking, arcade building, design and what ever else i can to build some thing that literally is just a pure beast.
All in all the pc will have water cooled GPU's (graphics cards) - Sub zero CPU cooling and a few other bits and bobs to make this system just rocket.
and this is what happens when a phase unit is turned on with out protective layer ...
All that is then connected onto the CPU alone brining the temp of the cpu from around 34c to about - 30c / -40c
My only real problem will be getting every thing to fit.
Ive got to be able to fit all this inside c-macc's 2
« Last Edit: July 31, 2009, 06:57:54 pm by mayhem »
mayhem
    • C-Macc's
« Reply #117 on: July 31, 2009, 07:04:47 pm »
this is the temps running a quad core
spOOf
  • Last login:March 27, 2010, 04:36:21 pm
« Reply #118 on: July 31, 2009, 11:23:11 pm »
 :notworthy:
My project: The Royal Flush
Franco B
« Reply #119 on: August 01, 2009, 01:14:26 am »
So how much are you spending so you can use a 'cheap' £48 cpu?
