Author Topic: XBOX 360 Street Fighter Stick #2  (Read 18116 times)
somunny
  • Is it hot in here?
« on: January 10, 2009, 09:11:16 pm »
I didn't take any progress pics of the first one I built (the red one in the pics below) so I thought I'd try to document the second one a little better.  The construction of the box will be the same.  Black laminate this time.  Different color t-molding and different cpo.
First stick:
Second stick - parts cut out and parts glued to laminate.
The sides are 5/8" and the top is 1/2" with .010 plexi on top.  Tomorrow I'm planning on trimming the pieces and getting the sides glued together.
Hopefully by the time I'm done with this stick, the gold laminate I have on order for the Ark will be in and I can get back to working on that beast.  ;)
Re: XBOX 360 Street Fighter Stick #2
« Reply #1 on: January 10, 2009, 09:35:40 pm »
can I get the plans for that? I cut the wood for a stick and it looks like crap compared to that
somunny
« Reply #2 on: January 10, 2009, 09:51:37 pm »
I didn't really use any plans but I'd be happy to draw up the dimensions for you.
Also, is it me or does the wood look all wavy in the second and third pics?  Must be the shadows.
bgspot
  • Last login:January 10, 2020, 12:37:52 pm
« Reply #3 on: January 10, 2009, 09:59:25 pm »
I like!! Nice clean and simple.
Gatsu
« Reply #4 on: January 10, 2009, 10:58:33 pm »
jeez man. take it easy on these things. you're making me look slow.  ;)
can't wait to see how it looks. I'm still waiting to get the t-molding in for my next stick...
« Reply #5 on: January 11, 2009, 09:44:22 am »
that would be awesome. If you could send me the artwork file too, to use as a template, I'd appreciate that too
EDIT:Removed email addy
« Last Edit: January 12, 2009, 07:50:51 pm by Malenko »
somunny
« Reply #6 on: January 11, 2009, 05:46:43 pm »
Got the pieces trimmed today and glued the corner blocks to the front and back panels.  I also routed out the lexan.  Unfortunately, something got underneath the router and scratched the Lexan through the protective film.  Total loss on that.
dmworking247
  • Last login:July 14, 2024, 01:30:59 pm
« Reply #7 on: January 11, 2009, 07:31:38 pm »
Nice sticks, they certainly seem more repeatable (less complicated joins etc) than my own.
Have you routed T-molding grooves in the side walls, and the CP top?
Is that plexi over the artwork? Did you have any trouble shaping the plexi and the artwork to the CP surface (ie rounding the corners, etc)?
Gatsu
« Reply #8 on: January 11, 2009, 11:04:25 pm »
looks really good man. What are you gonna use to put the bottom box together?
I got all the pieces cut out for my next 2 sticks. Just gotta get the laminate.....no luck finding a local distributor though. I asked everyone I could at Lowes and Home Depot...and no one seemed even slightly interested in helping me find what I needed. So I talked to a couple of managers (one in each store) and told them I didn't care to shop there if no one was willing to help.
So...gonna have to order it online somewhere.
somunny
« Reply #9 on: January 11, 2009, 11:25:27 pm »
Thanks, dm.  These are pretty much your basic-square-box-controllers.  Yep, all the t-molding routing is finished.  I use the cp as a template to route the Lexan out so it is the exact same shape (for better or worse!).  Once I adhere the cpo to the cp, I trim off the excess and it's all done.
I assemble the sides using glue only and then screw the cp and the bottom cover on.  No clear bottom for me.  This thing is big and there still doesn't seem to be enough room for a fancy wiring job.
Man, I can't believe it's so hard to get laminate out your way.  Hopefully you'll find a hook-up.
Namco
  • Last login:November 14, 2025, 12:56:14 am
    • Freddo Mame Project
« Reply #10 on: January 12, 2009, 06:41:11 pm »
I think most of us started with one of these kind of projects. The thing I hated with mine (besides the crappy woodworking) was how high it sat up in my lap and just how big the whole assembly was.
I love your first stick and now I'm thinking of building one, but with a focus on the ergonomics of it all. However with yours, I bet the size and the angle of it makes it mighty confortable. Let me know how it feels on your lap during a long play session.
massive88
« Reply #11 on: January 13, 2009, 12:45:21 pm »
Were you using Japanese parts or American?
My first Xbox stick I built (well, and all of them afterwards) were using japanese parts, and the box isnt tall or bulky at all imo.
Here are three that I have made (first two had the same build design):
Gatsu
« Reply #12 on: January 13, 2009, 01:37:26 pm »
what kind of stick is that in the 2nd one? It doesn't look like a JLF.
massive88
« Reply #13 on: January 13, 2009, 02:02:50 pm »
The Texas and Yankee sticks are using JLFs
The Black/White/Red stick is using a Seimitsu LS-32.  Its original purpose was to be a 4-way controller for a game competition/legacy trophy, and the Seimitsu rocks the 4-way much better than the JLF.  In fact I now want to replace the Happ 4-way in my stand-up machine with Seimitsu's because I like the feel so much better.
Namco
« Reply #14 on: January 13, 2009, 03:41:58 pm »
Yeah, your sticks are great. My first box had a Happ Ultimate (ugh), which has a very tall base and Happ Ultimate buttons which gave the cherry microswitch terminals pointing straight down. Needed 3 inches of clearance at least. Plus I built it out of 3/4" particle board so the thickness of the wood added a lot to the size.
When I have more time, I'll search for your project thread to see the images of the underside/insides. If you don't have one, please post one up. Thanks a bunch!!
« Last Edit: January 13, 2009, 03:44:46 pm by Namco »
dmworking247
« Reply #15 on: January 13, 2009, 07:04:53 pm »
I can't tell from your first post whether the back & front walls have an angled cut on them?
I can see an angle on the side walls so that the CP surface angles towards the player (excellent!) but I was wondering if you had to angle cut the top edges of the back/front walls, and whether that added a lot of complexity?
somunny
« Reply #16 on: January 13, 2009, 07:23:12 pm »
Yes the fron and back pieces are cut to match the angle of the side pieces.  If you have a table saw it's pretty simple to cut the angle.  I used the side piece as a guide to set the blade.  Just butt it up to the blade and adjust.
The height of the box is only 4 1/8" at it's tallest point.  Haven't played with it on my lap, though.  I normally set my other stick on the coffee table and play it that way.  My other stick is quite a bit bigger than the red Street Fighter one however.
massive88
« Reply #17 on: January 14, 2009, 02:46:50 pm »
Dunno if this was for me or not.  But I detailed my build here which includes some shots of the inside.
Mine are all 2 1/8" tall overall, I think you could make it as small as 1 3/4" with the Japanese parts, but I wanted some extra room for my first builds.  Also the wiring on the Texas stick is a nightmare, I did much better by the third one (the b/w/r one).
somunny
« Reply #18 on: January 14, 2009, 10:54:29 pm »
A little more progress tonight.  Tomorrow, I'm going to try and route out the Lexan and drill the holes in the top deck.
Gatsu
« Reply #19 on: January 15, 2009, 08:13:52 am »
Looking really good man. Any idea on the artwork? or are you saving that for the big finale?
massive88
« Reply #20 on: January 15, 2009, 10:58:56 am »
That does look really sharp.  I think Im going to have to try some laminate on my next project.
Have you ever considered making the laminate go all the way to the corners on the base, so that there is no T-molding on the bottom?  I think that would be the only change I would make if I did something like that.
« Reply #21 on: January 15, 2009, 12:12:01 pm »
Looking good!  Have you seen this trailer for SF4 yet?  It looks sooooooo good.  I wish I had the time to build a dedicated stick...
http://www.gametrailers.com/player/44357.html
  • Online Online
  • Last login:Today at 03:23:14 pm
« Reply #22 on: January 15, 2009, 04:31:18 pm »
Glad to see Akuma still has his Raging Demon...   >:D
Namco
« Reply #23 on: January 15, 2009, 04:38:06 pm »
Yessir, that was exactly what I was looking for. I want US arcade controls without the mess underneath. I can't have both and always wanted to get a balltop anyway. Looks like I'll be looking for some candy cab parts soon.  ;D
somunny
« Reply #24 on: January 15, 2009, 07:27:32 pm »
Thanks for all the positive comments, guys!  :cheers:
 ;)  Yes, but it's not anything real dramatic.  Just a different design.  I prefer the red artwork to this next one but we'll see how it comes out.
Yes, and I may do it that way on some future sticks but for now I'm doing it like that for two reasons: a) it's easier and b) the t-molding looks pretty decent when
color coordinated with the artwork.  I'll admit, a nice mitered corner is hard to beat.
SF4 is looking better and better.  I can't wait!
somunny
« Reply #25 on: January 15, 2009, 10:54:16 pm »
Progress tonight: Lower box assembly is complete.  Re-routed the Lexan.  No scratching this time.  Laid out the joystick and button placement.
Gatsu
« Reply #26 on: January 16, 2009, 12:12:24 am »
looking really good man. cant wait to see the finished stick.
massive88
« Reply #27 on: January 16, 2009, 09:35:18 am »
I have yet to work with Laminate at all, but what about not making mitered corners, and just putting the laminate to cover the butt joint?  For instance, laminate the long peices first, then glue the box together, then apply laminate on the short piece + ends of the longer pieces.  Trim and be done.
Just asking because I dont know!
somunny
« Reply #28 on: January 17, 2009, 07:03:29 pm »
Essentially finished the box today.  Still need to apply the artwork and t-molding (waiting for delivery).
Lexan and control panel drilled.
Pic of the drilled control panel.
Installed the USB pass through.  I'll paint the screws with some black nail polish later.
Attachine the top to the box.
Bondo can be a pain to work with sometimes but I like the way it comes out versus wood putty.
A few minutes with the palm sander and...
  • Online Online
« Reply #29 on: January 17, 2009, 11:00:43 pm »
Wow, looks great!  :o
Gatsu
« Reply #30 on: January 17, 2009, 11:15:21 pm »
sweet. I've gotta putty up some sticks in a day or two. Just waiting for my 30mm cutter bit to come in the mail so I can drill all the buttons out before I glue the next sanwa case together.
I'm hoping to have some photos up tomorrow night of my sticks progress. Got 4 in the works at the moment.
somunny
« Reply #31 on: January 18, 2009, 12:22:03 am »
Thanks, man.  When are you gonna build one?  :)
It's nice to have customers, right?  Looking forward to the pics.
somunny
« Reply #32 on: January 22, 2009, 08:48:03 pm »
Got the last of the buttons I was waiting for this afternoon.  The box is finished.  No controller or wiring, though.  I'm thinking of just selling populated shells and letting people do their own controllers and wiring.   I do have some hacked controllers left in the event someone wanted the whole package.
Anyway, on to the pics...
Gatsu
« Reply #33 on: January 22, 2009, 09:54:19 pm »
 :notworthy: :notworthy: :notworthy: :notworthy:
  • Online Online
« Reply #34 on: January 23, 2009, 07:42:38 am »
sju4sju
  • Last login:March 16, 2010, 12:22:57 pm
« Reply #35 on: January 23, 2009, 10:47:39 am »
Woah!  :applaud:
So how much d'you think you'd be charging for box+controls?
Namco
« Reply #36 on: January 23, 2009, 03:46:28 pm »
That's great man. What are the side buttons? Triggers or Back/Pause? Is the button that is next to the USB port the Xbox Guide button?
Just trying to figure out what kind of admin panel I should build when I put my Xbox in my SF2 cab.
Edit: What is the purpose of having the LB and RB on your layout? Are they going to be used for SF4 do you think?
« Last Edit: January 23, 2009, 03:51:30 pm by Namco »
somunny
« Reply #37 on: January 23, 2009, 06:38:35 pm »
Thanks, guys.   :)
Woah!  :applaud:
Thanks!  Sent you a pm.
Thanks.  The side buttons are start & back and the button next to the USB passthrough is Guide.  I went with the 8 button layout because, IIRC, the first Street Fighter released on XBLX let you map P and K x3 to those buttons.  I'm not sure if they'll play any future role but you never know...
SNAAKE
  • Trade Count: (+29)
  • Last login:November 24, 2025, 12:30:06 pm
« Reply #38 on: January 24, 2009, 03:30:24 pm »
did you really have to use american buttons? they are whack compared to japanese sanwa. just a thought. give those a try you wont regret it. stick itself looks great though and nice artwork.
somunny
« Reply #39 on: January 24, 2009, 03:46:45 pm »
What about the stick?  Happs Comp versus Sanwa?  A valid suggestion that I may give a go.  I can't have my sticks being whack now, can I?  ;)
