Author Topic: Would this be a good pc for mame?  (Read 1615 times)
dreamakuma
  • Last login:July 08, 2010, 02:14:54 am
« on: January 09, 2009, 07:57:23 am »
I have mame 0.81(I belive) and i'm running Mame 32(not ui,old school 32,I got it all from a friend, which got me wanting arcade stuff, so I don't know much). Since I'm looking at the risks of how My CPS2 hardware will cost me, I think I'll mame.I don't need any fancy frontends because I'll be to busy playing games to care.  so would this pc work?
http://stlouis.craigslist.org/sys/965208320.html
Just want to know...Thanks
Newbie in working on cabs, expert in playing, breaking, moving slowly, and overall failing at them too.
jessybr
  • Last login:December 25, 2016, 05:54:07 am
Re: Would this be a good pc for mame?
« Reply #1 on: January 09, 2009, 08:07:24 am »
hello
ik think you should look for a pc that is al little faster then 1.8 more like a 2.4 and up
and also a bigger harddrive .
geetings from holland
Blanka
« Reply #2 on: January 09, 2009, 08:24:33 am »
If you play only 8-bit and 16-bit arcade games (up to multiple processor 68000 games), it will do great. For the more modern 32-bit games a fast Core2Duo is prefered.
dreamakuma
« Reply #3 on: January 09, 2009, 08:29:38 am »
jessybr
« Reply #4 on: January 09, 2009, 08:39:44 am »
yes that schould do better
Blanka
« Reply #5 on: January 09, 2009, 10:06:14 am »
Barely. Almost the double price for just 0,6 ghz extra is not doing much. Guess it still is limited to old games. If the second one is 100$, then it might be Ok.
dreamakuma
« Reply #6 on: January 09, 2009, 11:42:29 am »
Okay...would the second PC be able to play...Marvel vs capcom on mame? That's the newest game I got and the best I'm interested in playing. The cps 2 titles are where I get most of my gaming on, followed by neo geo titles.
CathalDublin
  • Last login:March 01, 2024, 04:05:23 pm
« Reply #7 on: January 09, 2009, 01:15:14 pm »
I'd try get a cheap dual core with 1gb ram minimun. It will be worth the extra few dollars
Defender(multiwilliams), SF2CE
Whirlwind, Lethal Weapon 3
jessybr
« Reply #8 on: January 09, 2009, 01:27:24 pm »
yes im runnig a 2.4 ghz with 1028 mb ram
and it runs almost everything
and some games will just run not good
neo geo goes without a problem
gonzo90017
« Reply #9 on: January 09, 2009, 02:12:01 pm »
Marvel vs Capcom runs full speed on my Pentium 2 @233mhz.
Just go with the first pc. And make sure you stick with the mame version you have and
don't try to upgrade to newer versions.
Jack Burton
  • Last login:August 26, 2023, 11:32:31 pm
« Reply #10 on: January 09, 2009, 05:13:03 pm »
Also, keep in mind that your operating system will influence your performance with MAME.
Linux compiled for your particular setup should give you a performance boost.
and yeah, if you are only interested in the classic stuff up to the CPS2 then just about anything that will run Windows XP will work.
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« Reply #11 on: January 10, 2009, 10:08:19 am »
I'd check out the cheap systems you can buy at any normal store or even Dell or something.  Most PCs come with fancy video cards and things like that which you don't need.  All you need is the fastest processor you can find and a bunch of memory so the OS doesn't hamper you.
GO to Dell's site and spec out a system by removing everything you don't need.  Can get a brand new one for just a couple hundred dollars.
Or even better, the Dell Outlet:
http://outlet.us.dell.com/ARBOnlineSales/topics/global.aspx/arb/online/en/InventorySearch?c=us&cs=22&l=en&s=dfh
« Last Edit: January 10, 2009, 10:10:41 am by kelemvor »
dreamakuma
« Reply #12 on: January 10, 2009, 10:56:35 am »
On both dell sites, I found most PC's to be $300+. And I can't wait on shipping because I have a due date.  I got to get it running by Feb 6. so I look locally. All I have to do Is get a PC that will run these ten year old games on mame,nothing fancy, no frontends, no advaned settings, just fullspeed,I don't even need highscores, just solid emulation. Then A cheap 21" CRT till I can buy A Wells Gardner D9800 from Xgaming($350 aint cheap where I'm from, so that will be after due date) and I'm looking at an Ipac ve to hook my joysticks and buttons to. Other than that and some work I'd be done. so I'm looking at the $50 and the $130 one. If both suck Please post a link to A suitable PC that will run up late cps2 and neo geo titles and xp, and cost less than $200. I'm on a very fixed budget.
kelemvor
« Reply #13 on: January 10, 2009, 11:05:05 am »
If all you need is those certain games, then the first one would probably work.  I'd definitely add more memory though (which is very cheap).
My machine is a P4 2.4 or 2.8 or something like that and it works fine.  I'm running Mame 106 or 115 or something in that range I think.  Haven't looked at it in a long time.
The ones at the Dell Outlet site are around $280 or so and would be far better for future upgrades and things but if that's not a concern, then go with the cheapie one.
If it turns out it's too slow, you could probably just put in a new processor as well and still be cheaper than that second one.
