Author Topic: Mounting plates  (Read 1447 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
Mounting plates
« on: June 22, 2003, 09:15:57 pm »
I have seen  examples of cps without mounting plates for spinners and trackballs. Is there a reason to have a mounting plate?  Are the plates on the example cps just flush with the cp so they can't be seen?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Mounting plates
« Reply #1 on: June 23, 2003, 01:42:17 am »
Mounting plates make mounting arcade TBs much easier on wood CPs than without them.  Arcade TBs are designed to be mounted on 1/16" (old style) or 3/16" (new "gloden tee" style) pieces of metal, not 3/4" or 1/2" pieces of wood.  Those mounting plates are the thin metal like the arcade TBs are designed for.
Others have mounted without mounting plates:
  • Spinners, like http://www.oscarcontrols.com/ used to come in both mounting plate and non-plate models, but I think most of them are now plate-less.
  • Non-arcade TBs don't have a standard plate to mount with, so most of those are plate-less.
  • As for arcade TBs, there are a few ways so you don't need a mounting plate.
    • Use a metal CP,
    • mount it directly to plexi/lexan tops instead of a metal plate,
    • or bottom and/or side mount.
    The last one can also be aided with laminate glued on the top; I can't remember exactly who did this method but you can search the forum (increase days to ~350)
Robin
Knowledge is Power
AlanS17
    • AlanS17
Re:Mounting plates
« Reply #2 on: June 23, 2003, 01:45:58 am »
If someone mounted directly to lexan (I was considering this idea though I hate the look of crriage bolts), how sturdy would it be?
skirge66
  • Last login:June 03, 2003, 06:25:58 am
  • the stupid will normally punish themselves
Re:Mounting plates
« Reply #3 on: June 23, 2003, 10:41:05 am »
the happs mounting plate I have has no visible carriage bolts, and if you recess the plate 1/16" you can cover it up with art, laminate, or anything else and it is invisible.
skirge66
Diplomacy is the art of saying "nice doggy" until you find a bigger rock to throw
Shieldwolf
  • SpearShield.com
Re:Mounting plates
« Reply #4 on: June 23, 2003, 02:12:36 pm »
That's a good idea, I wonder about recessing the plate, but I was afraid it would hinder gameplay somehow.
night
  • Last login:January 09, 2018, 02:08:19 pm
Re:Mounting plates
« Reply #5 on: July 07, 2003, 12:05:16 am »
which plate exactly ?
and high ball or normal?
AlanS17
    • AlanS17
Re:Mounting plates
« Reply #6 on: July 07, 2003, 12:25:50 am »
I'm going to be using the Happ flat-top mounting plate (don't know the real name for it) and I'll be recessing it. It seems to be the most professional way to do it. I know Bob Roberts sells them on his site, too.
