Author Topic: mame 32 minimizes while playing games. Please help.  (Read 869 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: January 03, 2009, 07:14:32 am »
Hi Can anyone tell me why mame 32 minimizes for no apparent reason when I'm playing games.    ???   Thanks
« Last Edit: January 03, 2009, 07:16:28 am by rlemmon »
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
Re: mame 32 minimizes while playing games. Please help.
« Reply #1 on: January 03, 2009, 09:57:45 am »
mine does it every like 100 times i play too, somwhow your buttons are not setup correctly
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: January 04, 2009, 02:59:02 am »
Most likely, your computer has a hotkey that is a key combo you can press with with your keyboard or keyboard encoder.  Either disable the hotkey (how varies on which app/driver has that hotkey), or remap both your keyboard encode and mame to not use the ctrl and alt keys (and maybe shift, too).
'm assuming it's not something like you're using a keyboard and you're accidentally pressing the windows key, and assuming you aren't using a gamepad or joypad encoder.
(BTW, that app is now called mameUI, unless you have an old version with the old name.)
Robin
Knowledge is Power
Ginsu Victim
  • Comanche, OK -- USA
« Reply #3 on: January 04, 2009, 11:38:08 am »
The way I fixed that was to set all my buttons to numbers and letters (along with the shifted Esc, of course), then remapped everything in my emulators. Wasn't that much work and I haven't had a problem since.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: January 04, 2009, 12:46:12 pm »
Could be related to the Windows "Start" key.
Also, Windows by default has a feature where a combo of key presses does some things (like Shift-control + something else to switch to other language modes). I forget where those options are, but it's on by default.  Check if you have a little icon on your taskbar with "EN" next to it. It's in there.
NO MORE!!
ghettodish
  • Last login:October 21, 2017, 03:41:58 pm
« Reply #5 on: January 04, 2009, 01:03:47 pm »
pressing alt+tab at the same time will do it
rlemmon
« Reply #6 on: January 05, 2009, 12:50:08 am »
Thanks for all your help guys, I'm going to try your suggestions as soon as i have the time.    :notworthy: :notworthy: :notworthy:
Ummon
  • Trade Count: (+13)
« Reply #7 on: January 07, 2009, 07:06:57 pm »
Yeah, default Mame keycode set is LMAE....I mean LAME.
Yo. Chocolate.
Stephen Hawking
