Main > Everything Else
Hot water boiler installation. Where to start?
<< < (4/9) > >>
protokatie:
If you let daywayne play your arcade cab for a day, maybe he will do it for free: considering how easy he makes it sound  ;D
ChadTower:
--- Quote from: myntik1 on January 04, 2009, 10:41:27 pm ---The only thing that scares me more than electricity and water is natural gas and fire.
In other news he's only marginally terrified of earth and wind.   :)
Ed_McCarron:
--- Quote from: protokatie on January 04, 2009, 11:03:20 pm ---If you let daywayne play your arcade cab for a day, maybe he will do it for free: considering how easy he makes it sound  ;D
Its  honestly not tough; takes me about two hours to replace a gas hot water heater.
Helps if the pipe unions are in the right place.
lordtodd75:
Sorry about the confusion. I am actually talking about an oil boiler to heat my home. I had no idea it was as difficult and undoable as everyone is saying. I just thought pehaps someone could point me in the direction of some reading material to help me learn the ropes. It is very hard for me to pay $1000.00 to $2000.00 for 2 days worth of labor.
shardian:
I replaced my electric hot water heater. It was pretty easy. The only possible problem point is soldering skills.
Dawayne left out one important step in his soldering guide though - use the wire brush to clean both pieces being soldered. There is a special wire tool for standard 1/2" pipe that usually comes with the soldering kit you will buy anyways.
So.... clean/flux/heat until solder flows/solder are the basic steps. Oh, and take off the flame once solder starts to flow. That way the solder can be properly 'sweated' in.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
