Main > Everything Else
WD TV HD
<< < (2/12) > >>
Samstag:
--- Quote from: Blanka on January 02, 2009, 12:16:11 pm ---Why don't they make the case a tad bigger, and add an empty drive bay and a SATA and an Ethernet port?
Check out "Popcorn Hour" if that's what you need.  It's a really nice device, but less portable and much more expensive than I'd like.  There are other alternatives out there closer to your specs but the good ones are expensive and the cheap ones aren't usually very good.
hyiu:
ok... let me throw my question out, and see if it can be solved....
this WD HD box seems perfect...
only thing is, I have to copy the files to the external drive, and then plug the drive on...
is there a drive out there that can be connected to the WD HD box, and also connects to my house wireless network ??
That way, I can push the files thru the Wireless netowork (I know... this will be slow... but I'm not in a hurry) and then watch it there... no equipment needs to be moved...
is there such a solution out there ?? (I would prefer a not too expensive one if possible...)
Thanks,
richms:
No, you can just get a popcorn hour and have what you want.
There are going to be a lot more devices based on these chips soon enough. Its the home version of those car stereos that finally have left off the obsolete CD drive. Its just this one is sold excessivly cheap for the functionality it provides.
Edgedamage:
Get this firmware update it adds more video file support and more subtitle support.
http://www.wdc.com/en/products/wdtv/...sp?wdc_lang=en
Generic Eric:
I know its an old thread, but does anyone have any second thoughts on this?  I am thinking about getting one.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
