Main > Everything Else
WD TV HD
<< < (4/12) > >>
massive88:
--- Quote from: Generic Eric on June 17, 2009, 03:13:07 pm ---
--- Quote from: massive88 on June 17, 2009, 02:18:02 pm ---It still doesn't have network capability right?
I just cant fathom having to manually move files over constantly.  I guess if you have a stagnant set of video files it would be great, but I want to access things off my NAS that I download regularly.  A popcorn hour looks like a far better product for me.
Not out of the box, you have to use an unofficial firmware and use your own USB to ethernet, or USB to wireless adapter.
So even though its only $99, you have to had some more stuff on your own.  I also read that you may need a 2GB or less thumbdrive  to use some one of the firmwares.
Hrm, but after that you can use it to access network shares?  Do you still need an internal HDD?
I actually already have a USB to Cat5 and an 8gig thumbdrive...
ahofle:
I have one of these and it's great.  My biggest complaint is that it still can't handle some high bitrate 1080p content  (I believe this is a firmware problem though since the Popcorn hour has the same Sigma chip and handles them fine).  The inability to network it is sometimes a pain, but you can just spend 3 times as much on the PH if that's what you really want -- for $99 this thing is a frickin bargain for all it does.  I rip all my DVDs to it in mkv format -- no more fumbling around with discs or having the kids scratch them to hell.  Just go through the menus and pick the movie you want.  I also plan on getting a 2.5" external drive and transferring all my DV and HDV home movies to it in their native format after seeing that it can play 1080i m2ts files flawlessly.
shardian:
--- Quote from: ahofle on June 17, 2009, 04:16:07 pm --- I also plan on getting a 2.5" external drive and transferring all my DV and HDV home movies to it in their native format after seeing that it can play 1080i m2ts files flawlessly.
Bingo! This is one of the main reasons I want this thing.
Samstag:
--- Quote from: Generic Eric on June 17, 2009, 03:13:07 pm ---I also read that you may need a 2GB or less thumbdrive  to use some one of the firmwares.
That isn't true of the official firmware versions.  I have an 8g drive that has been working fine since 1.00.
Generic Eric:
--- Quote from: massive88 on June 17, 2009, 03:30:55 pm ---
I read that you need to do that with unofficial firmware
But I don't have a WDTV so I can't speak with any authority.
--- Quote from: Samstag on June 18, 2009, 09:58:18 am ---
I meant of the unofficial firmware    I just edited my earlier post.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
