Author Topic: Building your own Ambient Light system, using the LED Wiz piece (I need help!)  (Read 1658 times)
bleedscarlet
  • Last login:December 13, 2008, 10:34:54 am
So I've gotten as far as the testing procedures.
When I run the LED Wiz software and turn on the lights, they flash, or do whatever I want them to.
Does anyone have experience with boblight or any of those momo/atmolight softwares? I can't seem to get it to work...
arzoo
  • Last login:April 14, 2024, 11:15:11 am
  • Robots WILL kill you.
    • LEDBlinky
What exactly are you trying to do?
Robots will kill you.
Arcade Addiction
BASS!
  • Just have fun.
  • Last login:August 10, 2013, 03:12:33 am
either pimp out his car, or something interesting.
bleedscarlet
I'm trying to do this:
http://www.instructables.com/id/Building-your-own-color-LED-bars/
and I searched around for help, found this place.
I've troubleshooting as much as possible.
Dazz
  • Last login:March 30, 2024, 10:34:39 am
  • HyperSpin Team
    • VPUniverse
I know the guy that created this one...  Let me see if I can contact him and see if he'll post here.
Blanka
Just use an Arduino with some good power Mosfets. Cheaper and easier to program for stand alone use.
bleedscarlet
arduino is more expensive, I don't have any more money to spare on free projects for a while
Blanka
The arduino itself is cheaper (30$), but it depends on what you want to do. If you want a stand-alone 3 channel PWM RGB ambient light that runs by itself your personal pattern on some power leds (1A or more/channel), using direct input (some switches, a temp sensor, a touch sensor, RGB input) Arduino is easier and cheaper, and delivers 256 steps of brightness per channel. If you want to drive many lights up to 500mA/channel, use basic preprogrammed patterns, and don't mind the computer being on all the time, the LED wiz is a good choice.
