Main > Main Forum
HELP! LCD Topgun New Owner here!
Pages: << < (3/3)
slapaham:
Let me online what I have done just to make sure I've got this all correct...
Horizontal set up (a vertical one won't fit) - Power LED in bottom right hand corner of screen and wires hang from both strips to the left...
LEDs plug into gun... gun plugged into USB... gun recoil plug into Y cable which is plugged into other USB...
New hardware detected... install TopGun driver + panel v.1.0 beta 2 - picks up EMS LCD Topgun... install... then picks up HID mouse... install... then picks up HID device... install...
Restart computer...
no signs of life...
go into control panel... buttons function but mouse cursor doesn't move with gun only PS/2 mouse...
Point gun away from screen... press A and B together... Laser dot shows... point at Top right LED, shoot, then centre, shoot, then top left, shoot, then top right, shoot, then bottom right, shoot, then bottom left, shoot... nothing happens... laser dot still shows and now the buttons don't do anything when you press them... awesome!
Is there something I'm doing incorrectly here!? :banghead:
slapaham:
Anyone? I need to know whether it is defective or not so I can get a refund!! I don't want to give up on it but its getting to that point...
daywane:
I am also having the same problems.
I have been here and downloaded ALL Drivers.
1st PC would not install any of them :dunno
2ND PC has no problems except I can not calibrate.
cursor will not move :banghead:
download Smog's Guncon2 driver in google is not good eather
all links point to a dead web sight.
if anyone has alink for  Smog's Guncon2 driver I would be very thankfull
or email me the driver please
edit after PM
I have PM slapaham
he has his working now
after a email from him
I found out one thing.
My screen is not flashing when I shoot the gun.
I will add USB extentions and see if standing back farther will help.
daywane:
I have been reading the wiki
http://wiki.arcadecontrols.com/wiki/LCDTopGun#Hardware_calibration
I do not understand the
Software Calibration
It has been noticed that many different computer/driver combos have calibrated to the same numbers!
X Min = 160
X Max = 672
Y Min = 32
Y Max = 224
were do I put in these numbers?
I am working with Mame 32 v0.078
oh I missed this part.
EMS driver 3.1 does not appear to need software calibration
sorry
daywane:
problem solved.
use the wiki set up not the pdf from lcd web sight
keep at it
it will set up eventually
Pages: << < (3/3)
Go to full version
