Author Topic: Considering a bigger cabinet for my project - suggestions?  (Read 865 times)
cmoses
« on: December 09, 2008, 11:43:38 am »
I have reached a crossroads in my project and am looking for some suggestions.  I purchased a Taito cabinet that was in very bad condition with the intent to MAME it.  I have completed stage I of this build and have learned a lot and am really enjoying the process.  The machine is up and running MAME and I am enjoying it a lot.  I would like to some more player buttons, a trackball and spinners to allow me to play more games.  I purchased a spare control panel and would use it to start planning the additions.  The main issue is that the Taito is on the small side.  So I am debating between staying with the Taito and giving some additions up or getting a little larger cabinet.
I would like a cabinet that has a separate control panel box.  This way I could build it to size and configure it with the components I wanted.  Ideally I would like a 2 player CP with 6 or 7 buttons per player, a centrally located trackball and a spinner for each player for racing games.  I am looking for some suggestions on cabinets that would meet this criteria.
I have seen the Midway cabinets that were used for NFL Blitz and Mortal Kombat and like them.  I like the separate CP boxes they have and would probably design a CP somewhere between the 2 player Mortal Kombat size and the 4 player NFL Blitz size.
Are they other cabinets out there that anyone can suggest that would also fit these needs?  Any suggestions would be appreciated.  I have searched for projects with the Midway cabinets and there are a lot to use for suggestions.
Jimbo
  • Last login:May 04, 2024, 01:20:14 pm
    • Wood Finishes Direct
Re: Considering a bigger cabinet for my project - suggestions?
« Reply #1 on: December 09, 2008, 12:27:41 pm »
If you're looking to build your own panel, check out my project (link below)... what you mentioned is exactly how I have my CP, so it might help you with spacing of controls etc.
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
« Reply #2 on: December 09, 2008, 12:32:35 pm »
How about something like a Dynamo Showcase cabinet?  I have one and it seems something that you may want to check out.
http://www.americanvending.com/html/amusement/misc/cabinet/showcase.htm
Paul Olson
  • Last login:May 07, 2024, 03:19:08 pm
    • Paul's Arcade
« Reply #3 on: December 09, 2008, 02:27:48 pm »
I used one of the blitz type cabs for mine, and it has been great. I originally had a 2 player cp with a trackball and spinner. Everything was spaced well, but if you add anything else, it will get cluttered really quick. I ended up going modular which was easy to implement because of the seperate cp. The cp is 34 inches wide, which feels perfect for 2 full grown (even overgrown) adults to play side by side. It doesn't feel too big when I have a single player layout on there either. I originally planned to build a cab, but this one works so well, I would probably just copy it, so it doesn't seem worth the effort.
daywane
  • Last login:Yesterday at 03:54:32 pm
  • GRRRR!
« Reply #4 on: December 09, 2008, 03:11:42 pm »
i agree with pcolson
modular or swapable
cmoses
« Reply #5 on: December 09, 2008, 11:39:47 pm »
I don't wish to do modular or swapable.  I could accomplish that with my exisiting cabinet.  I am looking to go bigger so that I can have everything I want in one.
I am still trying to stay average in size, so a showcase is also out of the question.
Jimbo, I have seen yours and like the design a lot.  If I could find something that wide I could make it work as well.
My Taito cabinet is only about 24" wide, so it is very tight.  I have determined that 2 players 6 or 7 buttons each, a trackball and 2 spinners will satisfy my needs.  I just think I need to find something with more room on the CP.  Need to find something that I can convert, not ready to build my own as of yet.
severdhed
  • RIP Dinosaur Hippo
« Reply #6 on: December 10, 2008, 12:13:46 am »
you could always cut out a notch in the sides of the cabinet, and build a control panel box like you are looking for.  without seeing your cabinet, i dont know how well it would work, but that is what i did with mine.  it was 24" wide, so i cut out the sides a little and built a control panel box that is 30" wide, and now it fits everything.  here is what i am talking about, i have since built a nicer control panel, and better MALA layout, just not taken pics of it yet.
here it is with the new control panel box
« Last Edit: December 10, 2008, 12:15:18 am by severdhed »
Paul Olson
    • Paul's Arcade
« Reply #7 on: December 10, 2008, 12:39:48 am »
Here is mine before the modular project:
That is 34" wide, and all of the controls fit nicely.
I always suggest modular panels, but I realized you weren't asking about it. I was saying that the with this type of cab, you will be able to do what you want. I think the size of the CP is just about perfect for anything, which is why I made the modular panel to match it exactly. The panel is not awkwardly deep either. The whole panel is removable with 3 bolts so you can fit the cab through doors.
« Last Edit: December 10, 2008, 12:56:55 am by pcolson »
