Main > Project Announcements
Infinicade (fka My Cab Without a Name)
Pages: << < (6/14) > >>
TAG:
--- Quote from: Bender on January 19, 2009, 02:52:41 pm ---Its coming together nicely  :cheers:
what are those quick release thingies?
Thanks!  I got the pins off eBay, but the manufacturer's website is here)
TAG:
I got a lot done this weekend, which was a welcome change from recent weeks!
First up, installing the keyboard drawer.
The drawer slides that I picked up from Woodcraft worked beautifully.  I even rounded the bottom edge of the drawer front to minimize injuries to toddlers...and also as an excuse to use the router again.  I added a cabinet lock on the drawer for more protection from toddlers.  I figure I’ll keep the key on the same chain as the key for the coin door and store it on top of the cab or in a drawer in the rec room.
Next up was installing the front door using recessed European hinges that I also found at Woodcraft.  While I thought this might be complicated, it was actually pretty straightforward.
Then I added the sliding bolt on the other side and a stop on the cabinet side to prevent the door from swinging too far in.
Then, figuring that I was done getting into the cab, I turned the cab on its side and installed the casters.  I used swivel casters with brakes up front and fixed casters in the back.
Since it felt like I was on a roll, I went ahead and covered all the countersunk screws with wood filler, then sanded them smooth.  For sleekness and protection from bumps and scrapes, I used a Dremel to round the remaining sharp corners.  I suppose this will also help when installing the t-molding.
And suddenly, there it was: the completed (although still unpainted) arcade cabinet!!!!
Next up is priming and painting, which will probably take quite awhile because, well, it’s cold out and I don’t have anywhere to paint indoors where it’s both warm and well-ventilated.
You know, if I had any sense (and by “sense” I really mean patience) whatsoever, I’d wait a few weeks until it warms up before painting this thing.  I have plenty of other things to do, like getting the software set up, working on the control panel, etc.  I guess I'll just see how the weather is next weekend and wing it.
As always, thanks for reading!
shags0024:
Your cab looks great.
Excellent descriptions on the build.
thanks
Ond:
Beautifully documented, with alot of care and patience evident in your wood work, I look forward to seeing more. That's a very nice router too, mine is now the unpredictable beast you feared a router might be  :laugh:
ivwshane:
--- Quote from: Bender on January 13, 2009, 12:10:14 am ---Great progress so far!
I can't believe this is your first time with a router  :cheers:
just curious why you decided on MDO?
I love the stuff, but not many other people seem to use it for there cabs
That's because you can't find MDO every where! I'd love to use it but I've never seen it in person around my area:(
Go to full version
