Main > Everything Else
Now my morning
<< < (8/9) > >>
ChadTower:
--- Quote from: daywane on December 09, 2008, 01:32:20 pm ---my s10 blazer is doing it now.
when you turn on heat, It works right?
just blow from defroster?
if this is so. yep you have a vacume leak under the hood.
Not quite... air blows fine from heat vents.  It just never gets warm.  You have to use the defroster to get any warm air.
daywane:
Well then,,, Vacuum line is not the case.
thermostat is working because you get heat from defrost
Radiator is fine because you get heat from defrost
same with heater core
so I would start with a switch from a junk yard.
ChadTower:
--- Quote from: daywane on December 09, 2008, 01:44:34 pm ---thermostat is working because you get heat from defrost
Plus the car wouldn't run if these things were bad.   :)
daywane:
--- Quote from: ChadTower on December 09, 2008, 01:50:54 pm ---
wrong.
thermostat can get stuck open. Car will run fine. but never heat up water for heat.
you are right about  Radiator .
DaOld Man:
This is why I always try to buy a vehicle with a temp gauge, not just a "Engine Hot" idiot light.
The gauge will tell you if you got a bad thermostat, motor wont ever get up to normal temp.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
