| Main > Main Forum |
| ANSWER FOUND - Taking apart a U360 |
| << < (2/2) |
| GAtekwriter:
The "extra insert" I mentioned is a small black tube, maybe 1/2" in height that goes around the long metal rod. I couldn't figure out if it went above or below the 4-prong black plastic piece that screws down to the electronic base. It goes above. This is the only way you can add the longer rod and have the magnet at the bottom at the same height/distance from the sensor in the electronic base. |
| Ummon:
Oh, I thought it was part of....I dunno, something to do with the heavier spring. I got longer shafts with my sticks and I don't recall any extra hardware. I wouldn't think there'd be any as only the part above the base is longer. The part below should be the same and was when I compared mine. |
| GAtekwriter:
I'll try and take a picture tonight, but if I remember correctly the longer shaft, when installed, has a slightly smaller diameter about 1/2" above the top of the mounting plate... this is where the black insert goes over. Maybe it's not required, but since I got one with my kit I just had to figure out what it was for - it looks nice, too. |
| AndyWarne:
You are correct but that only applies to the shaft for the Oval top, not the ball top. Andy |
| Ummon:
The details surface. I have ball tops. |
| Navigation |
| Message Index |
| Previous page |
