Main > Everything Else
electronics question
<< < (2/2)
DaOld Man:
I dont know how electrically inclined you are, but you can build one using a 556 IC timer.
BORIStheBLADE:
--- Quote from: DaOld Man on November 27, 2008, 09:42:18 am ---I dont know how electrically inclined you are, but you can build one using a 556 IC timer.
Thanks for the info, I'm going to look into them.
DaOld Man:
Although it would be more expensive, you could use a nutchip.
It has 4 inputs and 4 outputs.
You could tie four dip switches to the inputs and give you the selectable timing rates you are looking for.
The nutchip is programmable with a serial connection to your computer.
Once you program it, you dont need to leave it connected to the PC. Plus it uses 5 volt power.
Learn more about the Nutchip
Edit: I was thinking of another post where someone wanted 5 volt timers. You will need to add a 5 volt regulator to use the nutchip on 12 volts.
Navigation
[0] Message Index
[*] Previous page
Go to full version
