Author Topic: Circuit Design Help  (Read 880 times)
Dudeman
  • Last login:December 30, 2023, 06:30:25 pm
  • Ecky ecky ecky ecky P'Tang! Zoop-boing mmmzoesm...
Circuit Design Help
« on: November 25, 2008, 04:05:31 pm »
I need a bit of help here.
I need to build a circuit that will cut off to current flow when the 2 parts are not in line. I My first thought was a magnetic reed switch like in the drawing, but I want to make sure a reed switch  can handle that load. I figure I'll be pumping 1A at 5VDC. The specs I've seen have "Switching Current" and "Contact Current" listed, but I'm not sure of the difference.
Does anyone know of a reed switch that can handle that, or any other ideas on how to accomplish this?
Dudeman
Re: Circuit Design Help
« Reply #1 on: November 25, 2008, 04:26:48 pm »
Update:
Seems that "Contact Current" is the maximum allowable current the device can carry continuously.
"Switching Current" is the maximum current the device can handle during switching operations without damage.
So I guess the following specs:
Reed Switch
Pull-In Amp Turns Max:32
Pull-In Amp Turns Min:18
Circuitry:SPST-NO
Switching Current Max:1A
Switching Voltage Max:200VDC
Mounting Type:PCB
Body Length:15mm
Breakdown Voltage Min:325VDC
Contact Current Max:500mA RoHS Compliant: Yes
Mean this one won't work because I need 1A Contact Current.
SavannahLion
« Reply #2 on: November 25, 2008, 06:25:27 pm »
Transistor or a relay if you're dead set on using this particular switch.
Dudeman
« Reply #3 on: November 26, 2008, 09:44:28 am »
Nope... not married to that. It is just an example of what I am finding. Reed switches that have a contact current of .5A. So I'm looking for one that can handle 1A, or another way of designing this circuit.
Beley
  • Last login:September 14, 2013, 09:02:37 pm
« Reply #4 on: November 26, 2008, 06:48:37 pm »
Most reed switches are fairly low current devices, you may find it easier to use a relay.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: November 26, 2008, 07:29:28 pm »
Other options besides reed switches include inductive sensors and Hall Effect switches (digital).  However, the former requires constant AC current, and the latter usually is more costly & lower current than reed and still requires magnet and a relay.
I think most BYO window/door sensors use reed switches.
Robin
Knowledge is Power
