Author Topic: Newbie help with encoders  (Read 934 times)
KapnKerfuffle
  • Last login:November 23, 2016, 11:48:14 pm
« on: November 18, 2008, 07:35:16 am »
Hi all, I could really use some help with choosing the right encoder(s) for these controls.  I'm want to use Happ rotary optical joysticks because I want to play Ikari Warrior type games.  I've seen the thread about the pros and cons of optical versus mechanical and I thought optical would be a good overall choice.  Here are the controls I would like to go with.
2 Happ Optical Rotary
2 sets of 7 player buttons
Exit, Reset, 1P, 2P, 1P COIN, 2P COIN, PAUSE, MENU
Trackball + 2 mouse buttons
Spinner
4 way joystick
What would I need to use to hook up all these controls?  Thanks in advance.
Think the Unthinkable, Know the Unknowable,
Screw the Inscrutable and Eff the Ineffable.
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
Re: Newbie help with encoders
« Reply #1 on: November 18, 2008, 08:02:11 am »
This should handle it...
http://www.ultimarc.com/ipac1.html
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: November 18, 2008, 08:14:24 am »
What about the rotaries, the trackball and spinner ?
 :dizzy:
Working: Not Enough
Projects: Too Many
Progress: None
KapnKerfuffle
« Reply #3 on: November 18, 2008, 07:29:34 pm »
Yep, the rotary on the joystick is my concern.
I do like the I-Pac.  It seems like it will cover my joystick directions and all my player button, plus two admin buttons if I'm thinking right.
But that leaves my 2 rotaries, spinner, trackball, and 4-way, plus some admin and mouse buttons.
If I got an Opti-pac with my I-Pac, would I be covered then?  Can two encoders be used at once?  That might be dumb question but I'm a nooblet so I'll throw it out there.   :dunno
Thanks for the replies.
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« Reply #4 on: November 18, 2008, 07:50:12 pm »
What about Ultimarc's U-HID?  That should handle most of that.
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #5 on: November 20, 2008, 04:51:13 pm »
Depends. ;D
The U-HID will do it, but might be more than you need.
Does the TBs come with PC USB boards, or arcade broads?  The spinner?  If all three have USB boards, you can use the minipac instead.
Other option is ipac + optipac.  The optipac can handle 8 mice axes inputs (it outputs 4, as 2 mice each with 2 axes).
Robin
Knowledge is Power
