Main > Everything Else
Mac vs. PC(pic)
<< < (7/11) > >>
Xiaou2:
Being an avid computerist  heh...  I can tell you that Im not a fan of the Mac.
 I had to work on one a short time ago at my job.  Replacing the Hard drive
was a nightmare.  You need a special tool just to open the thing, which I didnt
have.  Had to destroy on of my credit cards to get it opened. (no big loss cause
I was never going to use it... but what a pain)
 Once opened,  you have several screws and cables that must be disconnected...
but thats only after you spend 15 minutes trying to undo the EM shielding without
tearing it to shreads. (thin metalic foil that is glued in place firmly. Sorta like
aluminum foil.. but a little more heavy duty)
 Two of them needed Hard drive replacement.. and its no wonder... because there
is almost no airflow in that thing.   The things were cooked to an early death.
 On a pc, I can rip out one of my HDs in 2 min tops.   I can add as many as I need
without needing some slow USB connection.  I can tweak my hardware when things
need upgrading such as Video cards with dual monitor out, HDMI, etc.  If a part goes
bad, its easy to replace without some uber expensive hard to get hold of part.
 As for the OS... While I didnt spend a lot of time with it... I cant say that I was
impressed.  It was just about as cumbersome and inefficient as any other OS...
and didnt seem like you could tweak it too much to your liking, as I could with Xp.
 I didnt like the Keyboard at all.  No concave buttons make it too easy to slip
off them and not know which letter you are pressing.  They didnt have a good feel
to them either.
 While Windows is filled with problems that I really hate... I still prefer it for the
advantages it has over Macs.
 As for the Creative aspects... I find that argument really funny.   Windows can operate any of the big name creative programs such as Photoshop, 3d studio max..etc.  Theres
probably more software dedicated to creation on pc than there ever will be on
a Mac os.
Zero_Hour:
I'm going to assume that you were working on an iMac or a mini (not sure about how the minis open), but the problems you speak of aren't unique to iMacs, rather just about any "all in one" computer. I 've had to work on a lot of hardware over the years, and the Gateway Astro takes the prize for worst system I've ever had to crack open. Of course the success of the iMacs only increases the chance that you'll get to repeat the process you described. Conversely, a Mac Pro is one of the simplest computers to work on I've ever encountered.
AtomSmasher:
--- Quote from: ChadTower on November 18, 2008, 05:02:31 pm ---
--- Quote from: AtomSmasher on November 18, 2008, 04:41:04 pm --- I even recently saw a video game benchmark comparison between Vista and XP and the frame rates were virtually identical.
I'm not sure "it isn't slower than the last version" is much of an endorsement.
When Vista came out it was significantly slower then XP in video game performance, but the problem turned out to be poor video drivers, which has since been resolved, so it is a point worth making.  Also, this was a directX 9 to directX 9 comparison, so if you upgrade to directX 10, you will see a significant graphical improvement on several games.
patrickl:
Well since the OS is supposed to do more and it still does things at the same pace that is an endorsement. Sort of.
The performance differences between XP and Vista have disappeared with SP1 for Vista. The driver problems should be sorted by now. Vista is more secure than Windows XP (and it's certainly is a hell of a lot more secure than OS X). So, what is there still to complain about Vista?
I got Vista with a new notebook that I purchased so I had no driver problems. It hasn't crashed on me yet (used the thing for a year now). The only problem I had was with installing a USB temperature sensor, but that didn't install on a Windows XP machine either.
Lol, I looked for some benchmarks and apparently Vista is faster on a Mac Pro than OS X  :laugh2:
Xiaou2:
Imac.
 I really dont like the compact cases on some pcs.. but  they are
cake compared to the Imac's.   The EM shielding removal took me like 15 min
(and another 10 to put it back on!).. let alone getting the darn thing opened without scratching it or breaking the shell.
 I build my own pcs,  and upgrading/working on them is a cinch.  Buying a storebought pc
is a horrible waste of money.   Pay 2 times as much for hardware that is
snail slow, an OS loaded with crapware, and the hardware probably cant be upgraded.  (maxed out the day you buy it)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
