Main > Everything Else
15 years.....gone. Thanks Windows.
ark_ader:
Depends on how you view 15 years.
If it was precious - I'd take the drive to a professional.
If it was oops i learn't my lesson - try to recover it yourself.
Remember recovering data is one thing. Recovering data using the wrong tools will make it worse, or near impossible to get back.
I would start thinking of getting a NAS or a USB external. I have both and use HDD for archival use. At the end of the day its cheaper to store on HDD than burning to DVD. I had to recover and destroy 1000 DVDs with film stock I created with my video camera. It took two weeks non stop getting it off the discs.
Grasshopper:
--- Quote from: ChadTower on November 14, 2008, 10:33:54 am ---Ow... ow.
Always disconnect data storage drives when making OS changes. Don't store valuable data on your OS drive with Windows. Keep them physically separate - not even separate partitions, keep the valuable stuff on a drive you can unplug when there is potential danger.
I totally agree with this. It’s the only way to be sure.
A few months ago I set up a dual boot Windows XP/Linux system. I already had XP on my main hard disk and didn’t want to risk shrinking the XP partition. So I decided to put Linux on a smaller secondary hard disk I had lying around. I physically disconnected the XP drive and then changed the BIOS disk boot sequence before installing Linux on the second disk. I then reconnected the XP disk, put the BIOS settings back to what they were, and manually set up a dual boot system using Grub for DOS. It was a lot of extra work, and took a bit of trial and error to get right, but was absolutely worth it.
You simply cannot trust Windows. Another obnoxious “feature” of the OS is that it has a habit of silently writing over the MBR. This is OK if Windows is the only OS on your computer but it can screw up a dual boot system.
SavannahLion:
--- Quote from: Grasshopper on November 14, 2008, 02:24:33 pm ---You simply cannot trust Windows. Another obnoxious “feature” of the OS is that it has a habit of silently writing over the MBR. This is OK if Windows is the only OS on your computer but it can screw up a dual boot system.
That was the only reason I stayed with floppies for so damn long. It was less effort to keep a small 3.5 half in a drive than it was to mess with a trashed MBR every time Windows decided it knew my box better than I did.
Level42:
ChadTower:
Those commercials make me want to buy a Mac and destroy it yelling "WHY DID YOU HAVE TO MAKE DIE HARD IV SUCK SO BAD?! IT IS ALL YOUR FAULT! KEEP KEVIN SMITH OUT OF MY ACTION MOVIES!"
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
