Main > Everything Else
Network Issues
<< < (5/12) > >>
FrizzleFried:
How do you make it "run"... I don't see an option to turn a service on or off from within MSCONFIG.
SavannahLion:
--- Quote from: FrizzleFried on November 14, 2008, 12:53:27 am ---How do you make it "run"... I don't see an option to turn a service on or off from within MSCONFIG.
Start\Control Panel\Administrative Tools\Services
or
Run services.msc
While you're at it. Download and install nmap for Windows on a computer different than the problematic one. A simple port scan (eg nmap xxx.xxx.xxx.xxx) will reveal whether the correct ports are open.
FrizzleFried:
I dunno... server service is up and running... all services related to networking that I can see are up and running.
saint:
Three thoughts next:
1. Run "msconfig" and make note of every line's status in both the 'services' and 'startup' tabs as to whether they're set to run or not. Then turn them all on and reboot and see if that fixes it. Make sure you note which ones were on/off so you can put them back the way they were. This is just an experiment to see if you've got something important turned off. If so we can start troubleshooting from there.
2. Reboot the cocktail in "safe mode with networking" mode, and see if you can ping it from your main computer then.
3. Is the main computer on DHCP as well, or static?  From both computers, run a CMD prompt and then do an "ipconfig /all" -- capture the results and post them here.
CCM:
What firewall software are you running?  I use Zone Alarm and have added my home network (range of IPs) to the trusted zone.  Is it possible you have a similar setup and your cocktail is somehow getting an IP assigned to it that is outside your trusted zone?
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
