Author Topic: Anyone need cam locks for your coin door or back door?  (Read 18799 times)
dtechlogic
  • Last login:July 09, 2010, 04:46:57 pm
Re: Anyone need cam locks for your coin door or back door?
« Reply #40 on: September 24, 2009, 01:34:18 am »
I will take 4 for a neogeo MVS Cabinet. I need one for the coin door and the coin collector door and two for the top of the cabinet were the speaker are located. Let me know if those lock will work with it please
Beretta
« Reply #41 on: September 24, 2009, 03:09:49 am »
question.. how do i measure to find out what size i need?
is it from nose to tail? or do you measure only the threaded part or what?
2600
« Reply #42 on: September 24, 2009, 10:27:09 am »
What model lock?  C625? Will it come with a straight and offset cam?
It only comes with a straight cam.  I /think/ it's a C625.
Obviously it's up to you, but I wonder if it would be better or easier to just offer 7/8 locks and have them come with a straight and offset cam.  Then the user has the option of using it as a 7/8" lock or a 1 1/8" lock or even a 5/8" lock.  Also, you would only have to buy 1 size lock and it might be easier to stock or make your minimum purchase.  Thoughts?
SirPeale
  • Green Mountain Man
« Reply #43 on: September 24, 2009, 12:32:48 pm »
That would involve getting the separate cams.  I can see if I can get the offsets, but the place I'm purchasing them from has assured me that regardless of length I can still get the quantity discount.
You measure the threaded part, yes.  Over/Under doors, Coin Controls doors (like you'd find on a Williams Classic cab) take a 7/8" lock.  Midway doors (Pac-Man, Galaga, etc) take a 1 1/8".
The coin doors are easy - 7/8" (over/under, correct?).  I believe the upper ones are 5/8", and I wouldn't replace them if you already have them.  Keep that key in your coin door.  I'm sure someone more knowledgeable than I about Neo Geo cabs will speak up...
dtechlogic
« Reply #44 on: September 24, 2009, 02:36:03 pm »
I don't have the key to them. I just obtain the cabinet less then a week and also the locks are busted on top part. i am going to unscrew them  today.
SirPeale
« Reply #45 on: September 24, 2009, 07:12:42 pm »
Measure them, they're measured by the threaded part.  I think they're 5/8".  I can see if I can get a couple of them while I'm @ it.
They also might be special because don't they have a lock bar or some kind of hasp?  It's been a while since I worked on a Neo Geo cab.
Pics are handy.
MKFan4Life
  • Last login:July 24, 2023, 08:18:00 am
  • My arcade machines...
« Reply #46 on: September 26, 2009, 03:46:23 am »
Could use (2) for my Gauntlet Legends cab.  Should be Wells-Gardner Part #891-0547-00 double D cam lock.  Over/Under two entry coin door.  Can't measure the size, 'cause it came with no locks at all installed!  Can't find the dimensions for this part # online either.  Would it be a 7/8" length?  Door thickness appears to be 3/4" and where it shuts, the frame is close to 1" thick.  ???  What do you think?
SirPeale
« Reply #47 on: September 26, 2009, 01:02:15 pm »
As I stated above, over/under doors take a 7/8" lock.  I've never seen one that has not, anyway.
sayitaintjonas
  • Last login:June 27, 2019, 10:56:55 am
« Reply #48 on: September 30, 2009, 09:56:19 am »
You can put me down for 12. One of my candy cabs needs 7 locks alone!
I'll get you all the sizes if this order goes through :)
SirPeale
« Reply #49 on: September 30, 2009, 10:23:11 am »
The order is going thru.  I need those sizes!
sayitaintjonas
« Reply #50 on: September 30, 2009, 02:51:26 pm »
Glad to hear it  :applaud:
Will measure and get back to you tonight. Thanks!
Sain
  • Last login:November 27, 2009, 03:28:02 pm
« Reply #51 on: October 09, 2009, 05:04:35 pm »
You can mark me down for 2 - 7/8th
SirPeale
« Reply #52 on: October 09, 2009, 05:37:45 pm »
Thanks Sain.
I've had several people ask me about 5/8".  I'll find out.
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
SirPeale
Hoopz
SirPeale
2600
« Reply #57 on: October 13, 2009, 04:11:48 pm »
Any word on when you think you'll place the order?
SirPeale
« Reply #58 on: October 14, 2009, 12:24:53 am »
I'm thinking very soon.  I've had the number I needed for a while now, but people keep asking about them, so I've put it off.  Those numbers have dwindled now, so...
Anyone else?  Last chance.
SirPeale
« Reply #59 on: October 14, 2009, 02:07:18 pm »
The good news: I can get 5/8" locks.
The bad news: They won't have the same key as the 7/8" and the 1 1/8" ones.  But all the 5/8" will have the same key within themselves.
Also: no offset cams available.  Sorry.
So: consider this a GO.  I'll be contacting those interested shortly with a total.  Please pay promptly to not hold others up.
MKFan4Life
« Reply #60 on: October 14, 2009, 03:50:32 pm »
Sending you the payment for (2) 7/8" locks right now (for Gauntlet Legends over/under door set).  Thanks!
SirPeale
« Reply #61 on: October 15, 2009, 01:14:00 pm »
I have now PM'd everyone that contacted me either via PM or in this thread with a total and a Paypal address.  Even if you can't pay right away, please respond.
SirPeale
« Reply #62 on: October 18, 2009, 08:25:56 pm »
Nearly everyone has paid.  Order will be placed Monday.
MKFan4Life
« Reply #63 on: October 22, 2009, 01:55:45 pm »
Thanks for the help.  ;D
SirPeale
« Reply #64 on: October 23, 2009, 01:18:31 pm »
Received the locks yesterday.  I'll be boxing over the weekend.  I've got like 30 orders to fill, so it'll take me a while.
2600
« Reply #65 on: October 23, 2009, 05:42:05 pm »
Excellent.  Thanks for going through with this.
SirPeale
« Reply #66 on: October 29, 2009, 02:36:42 pm »
Despite my best intentions to get things packed up this past weekend, and every day since then, I've had one Real Life(tm) problem after another stack up.  However, today my assistant and I (my four year old) have been diligently packing up orders.  Those I've already gotten to have probably received a Paypal notification about it.  Those I haven't will be done shortly.
Queeg
  • Last login:January 18, 2010, 11:12:13 pm
« Reply #67 on: October 30, 2009, 11:01:34 pm »
Hello,
Just wondering if you still have enough locks for new orders. I only need 1 7/8" lock.
Any idea on shipping costs to Illinois?
SirPeale
« Reply #68 on: October 31, 2009, 07:53:50 am »
Check my store.
http://www.pealefamily.net/arcade/store/index.php?main_page=index&cPath=1
I'm afraid shipping isn't too pleasant though.
Red 5
  • Last login:January 08, 2021, 10:30:51 am
  • Do something stupid and we will make you famous
« Reply #69 on: October 31, 2009, 02:55:47 pm »
Got mine today  ;D.    Whohoo  :D
These are nice.
Thanks,
Jon
I accept CASH, Hostages and Gold Krugerrand
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:May 04, 2024, 09:08:32 am
« Reply #70 on: November 01, 2009, 08:33:11 pm »
Got mine - thanks!
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
MKFan4Life
« Reply #71 on: November 02, 2009, 01:29:12 pm »
I checked my mailbox this past Saturday, and someone by the name of "Peale" was kind enough to ship me some locks for my Gauntlet Legends game!  They fit and work perfectly... wow, how nice of this complete stranger.  Wonder how he knew I needed them?  Good job!  :lol
DashRendar
« Reply #72 on: November 10, 2009, 11:02:41 am »
I still need mine!   :dunno
SirPeale
« Reply #73 on: November 10, 2009, 11:35:30 am »
Sorry about that - you slipped under the radar.  I dropped your lock in the mail today.
