Author Topic: Happ Perfect 360 Wiring  (Read 3316 times)
Sensemann
  • Newbie
  • Last login:November 06, 2008, 10:53:49 pm
« on: November 06, 2008, 08:50:20 pm »
Hey folks,
I know I'm a complete newb, but hear me out.
I decided to upgrade from microswitch joysticks to Happ Perfect 360 optical sticks, but I'm confused by the wiring.
Happ didn't include any kind of instructions or diagrams for the wiring, and when I hooked up my 2-wire system (two wires, when crossed either directly or via a switch, complete the circuit and send the signal), either all 4 directions were on, or if I tried using 1 wire at a time, all 4 were off no matter what.
Anyone with a set of 360s want to set me straight?
Thanks,
-Rob
Stobe
  • Trade Count: (+17)
  • Last login:January 23, 2024, 05:08:05 pm
Re: Happ Perfect 360 Wiring
« Reply #1 on: November 07, 2008, 09:36:20 am »
There should be four connectors on the base, probably labeled U D L R for up, down, left and right.  Other than that, there should be a read and black wire for +5V and ground, respectively.
Since the P360 uses a little circuit board, it does not require a dedicated ground for each input.
Hope that helps.
-Stobe
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: November 07, 2008, 12:58:59 pm »
As Stobe hinted, the big difference between the p360 and a mircoswitch stick is the p360 needs power (5 V+) to power the optical sensors.  What are you hooking the joystick to?  (ipac, gpwiz, gamepad hack?)  You might be able to get the 5v+ from the encoder, depending which you have.  Or you might need to get it from the computer 5v+ or elsewhere.
Robin
Knowledge is Power
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« Reply #3 on: November 27, 2008, 01:01:55 pm »
Are there any step by step  directions on wiring of 2 p360's to a computer power supply. I'm assuming I would wire them to a molex, but I'm stumped after that. I haven't been able to find any detailed info on how to wire it.
DaveStall
  • Last login:February 19, 2021, 05:56:25 am
« Reply #4 on: November 27, 2008, 10:56:29 pm »
When I wired my P360s, I took the power from one of my motherboard's USB headers.  I just took a USB header cable and cut one end off (obviously not the end that plugs onto the header) and then took the +5V and the ground wires and connected them to a small terminal strip.  Then, run the P360 +5V and ground wires to the terminal strip.
Dave
Shieldwolf
  • SpearShield.com
« Reply #5 on: November 28, 2008, 04:18:29 pm »
Can anyone give a dummies' guide to connecting to a molex connecton?
Ummon
  • Trade Count: (+13)
« Reply #6 on: November 28, 2008, 10:15:10 pm »
Start reading basic electronics and applications.
Yo. Chocolate.
Stephen Hawking
Czapala
  • Last login:May 18, 2009, 11:04:35 am
« Reply #7 on: May 01, 2009, 08:43:18 am »
Dave
Did you use one USB cable PER joystick?
ie.  Did you use one or 2 USB cables?
.... then my daughter said "Daddy, those games are old."
Biscuit
  • Last login:May 22, 2012, 04:02:28 pm
  • I'm flakey.
« Reply #8 on: May 07, 2009, 08:57:41 am »
Dave
** BUMP **
I want to know this too.  Can you run more than one joystick to the terminal strip at that point?
genesim
  • Last login:April 12, 2010, 08:18:42 pm
« Reply #9 on: May 08, 2009, 12:29:07 pm »
But what are you using for a keyboard encoder?   Instead of banging your head against the wall, the Ipac has a +5 volt connector already there!  Thats the easiest way I can think of.
Also you can rig it from a power supply if you are using that for your arcade.
BobA
  • What Me Worry?
« Reply #10 on: May 08, 2009, 02:00:47 pm »
Dummies Guide
Molex connector
Pins    4
   Color    Type
Pin 1    Yellow    +12V
Pin 2    Black    Ground
Pin 3    Black    Ground
Pin 4    Red    +5V
The PC (power supply) side has female connectors
while the Drive side has male connectors.
You can get the female/male molex connectors anywhere PC parts are sold
or you can just cut the connector off and solder and insulate your wires.
Ummon
« Reply #11 on: May 08, 2009, 05:53:56 pm »
Both the Ultimarc and GGG encoders supply 5v, at least the former for up to four sticks.
Yo. Chocolate.
Stephen Hawking
