Main > Everything Else
What to charge for labor for a custom-built PC including OS install
DaveMMR:
I would charge about $100 for that service if all the parts are already purchased and all I have to do is pop them in the case and install the OS. If shopping needs to be done, I'd add an extra $25 (plus cost of parts, obviously).
If you have to do anything extraordinary (unnecessary but cool case mods, as an example), add more too. But otherwise, $100 seems like a fair price. Waiting around for an OS to install does not 'stop the clock' in my opinion.
Blanka:
I did not mention the hours on the progress bar, but on tweaking the setup to a more smooth one. For example to startup using all cores, setting up firewall, disable annoying warnings, trashing unnecessary startup items etc.
HaRuMaN:
Thanks for the feedback, there are obviously a lot of variables involved, and would likely need to be something decided on a case - by - case basis.
Most people here have chose the $101 to $150 option, that seems pretty reasonable.
ark_ader:
Go for the most expensive.
Go cheap and that is what you will get.
You get what you pay for.
HaRuMaN:
--- Quote from: ark_ader on November 05, 2008, 04:04:50 pm ---Go for the most expensive.
Huh?
I'm talking about what I would charge to do a custom build for someone else.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
