Author Topic: Have I bought a fake Seimitsu LS-32 stick?  (Read 5296 times)
zoltar
  • Last login:November 25, 2008, 07:15:36 am
« on: November 04, 2008, 08:55:59 pm »
I recently bought a Seimitsu LS-32 from starcab.net, and there are some strange things about it that makes me suspect that this isn't a real LS-32.  I was hoping someone could tell me if it's real or not.
(1) The holes in the mounting plate doesn't look like the holes I've seen in pictures of the LS-32.  It may be that there are a lot of mounting plate options, and if so, please let me know.  Here's a picture of my mounting plate:
(2) The microswitch terminals are not oriented in exactly the same way as the ones in other LS-32 pictures.  Again, here's a couple of pictures of the stick I received:
One more thing:  When I first got it, one of the four screws on top of the mounting plate wasn't screwed in straight.  This was because there wasn't a perfect fit between the holes in the mounting plate, and the holes in the blue plastic that it attaches to.  (I was able to make this a lot better by removing all four screws, and screwing each one a little bit while constantly alternating between them, making them go in in parallel.)
What do you guys think?  Is it possible that this is a fake LS-32 consisting of cheaper knockoff parts?
Bleagh
  • Last login:October 18, 2016, 04:33:25 pm
    • BLEAGH!
Re: Have I bought a fake Seimitsu LS-32 stick?
« Reply #1 on: November 05, 2008, 12:43:43 am »
There are surely knock offs out there.  Does the name Seimetsu appear anywhere on the stick?
zoltar
« Reply #2 on: November 05, 2008, 03:10:54 am »
No, not that I can see.  Where should it be written?
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
« Reply #3 on: November 05, 2008, 10:17:09 am »
haha seimitsu never use logo, only on PCB microswitches ver. LS-32-01
look OK for me
check microswitches, original is matsushita and have only 2 terminal
LS-32-01 use s-plate
on foto is normal LS-32 plate is ok
konckoff have Yenox, zippy and other crap micro
« Last Edit: November 05, 2008, 10:18:46 am by kowal »
zoltar
« Reply #4 on: November 05, 2008, 04:46:02 pm »
look OK for me
I opened it up, and it did use Matsushita switches. :)  Thanks for your help!
grantspain
  • Last login:Yesterday at 12:22:48 pm
« Reply #5 on: November 05, 2008, 05:01:05 pm »
it looks right but with new chinese versions it very difficult to tell,only real way is the actual operation of the stick
