Main > Audio/Jukebox/MP3 Forum
Another idea for jukebox decoration
NiN^_^NiN:
the best way is to cut the mic off and solder some wire from the speakers or soundcard so it beats from the direct source instead of the cab where sound echos and flashes on the vibrations.
Also there are 2 kinds 1 flashes to music and other does the same but u can set the tolerence for when to flash so it might flash onlu on beats AKA bass :)
spectre:
i know you can wire a stereo to use christmas lights...try that... dunno if thats the effect you want, lol...
BobA:
Just picked up a 3 channel color organ from Radio Shack to try to put in my jukebox.
It was on sale in Canada for $15.00 and regularly $70. It is not the regular christmas light type unit. It has 36 high power LEDs in 3 groups(red, yellow, green) of 12. It is powered by a 12V power adapter so is all low voltage DC. It is housed in a 12 inch by 10.5 inch by 6 inch speaker box with the regular front plate made up of diffused plexi.
The whole thing comes apart by unscrewing the back plate. All parts are mounted on the back plate including the leds.
It can be driven by an internal mike or has an rca jack for audio in. (mono)
All 3 channels are separately adjustable.
Just thought I would mention it as it has alot of potential for $15 Canadian. By the way there were only 4 in Edmonton and the flyer came out on Thursday June 19. You can check the Radio Shack CA web site for stock on this item.
Edit: RS No 4218905 Color Organ
BobA
filenabber:
--- Quote from: DJ Gary-N on June 18, 2003, 02:40:05 pm ---flash as I expected. they just kinda dim a little on and of.
I really like the way it does it. it does kind of fade in and out. I think it's cool. I'll post some pics of everyhting in a bit.
brian
aj6500:
Mine don't really dim. With loud volume they flash on and off. If the volume is lower, they shoot up and down. Kinda cool.
Navigation
[0] Message Index
[*] Previous page
Go to full version
