Author Topic: crazy question regarding small cellphone lcd screen  (Read 988 times)
clickhea
  • Last login:August 09, 2019, 07:33:40 am
« on: November 01, 2008, 04:47:00 pm »
i have a lcd screen from a blackberry curve
it wouldn't be possible to somehow wire this up to the computer to have it display certain things would it?
the connector to the lcd is weird so i wouldnt even know where to begin if it was even possible.
Re: crazy question regarding small cellphone lcd screen
« Reply #1 on: November 01, 2008, 04:54:18 pm »
The quick answer is no.
I'm making an assumption it's like a laptop LCD and it's not like a normal monitor. I did some research on something similar when I had a lot of junker laptops that had perfectly good monitors, but bad computers. You could do a ton of leg work and possibly get the thing working if you can find the proper driver (hardware and software) for the display, but odds are it won't be feasible.
I don't remember all the details of why it's so difficult, but I do remember that it wasn't simply a matter of a correct pinout.
clickhea
« Reply #2 on: November 01, 2008, 04:58:18 pm »
alright that's what i figured, thanks for the quick response.
Encryptor
  • Trade Count: (+34)
« Reply #3 on: November 01, 2008, 05:37:23 pm »
I believe that I read some where that it's because there isn't a controller built into those smaller lcd screens. Therefore there is nothing to convert/translate the signals going to the lcd or something along those lines anyway and the part to do that is very expensive.
Encryptor
« Reply #4 on: November 01, 2008, 06:25:53 pm »
Encryptor
Very good memory. That sounds familiar to me too.
clickhea
« Reply #5 on: November 02, 2008, 08:18:05 am »
ok heres a little spin on the question
i have the phone motherboard which the lcd screen connects too.
when i connect the lcd to the motherboard then connect the motherboard via usb to my computer i get a picture on the lcd of a battery symbol.
think there would be anyway to override this and have it display random things? or would i need a specific driver for this.
nox771
  • Last login:December 14, 2011, 08:50:12 am
    • rewiredgear
« Reply #6 on: November 02, 2008, 01:06:21 pm »
That's just the built-in firmware of the phone displaying the battery charge indicator when it detects power (via USB).  I don't think you will get what you want via that route.
To interface to a computer via USB you will likely have to build a microcontroller based interface (you may be able to find a dev board somewhere - prob $$$ though).
To build a microcontroller interface you would need to first find the datasheet for that display.  Something like the PDFs here:
http://www.crystalfontz.com/products/128128a/data_sheet/data_sheet.html
Then you would need to get familiar with a microcontroller, how to communicate via USB, and how to write the corresponding host-side software.  Been down that road, if your new to this kind of thing expect a year or so of learning.
There are some forums around that deal with this kind of thing.  You can try here:
http://forum.lcdinfo.com/
Now that I look at it perhaps that 13700 board they sell will work (that would save a heck of a lot of time):
http://www.lcdinfo.com/
You could try posting the LCD model info to that forum and ask if the controller will work.
« Reply #7 on: November 02, 2008, 01:55:07 pm »
Thanks for the informative post Nox. I wanted to say something similar to what you said (will cost a lot of money and isn't easy) but didn't feel qualified to say so since I'm not an expert on the matter. I remember walking away from this same type situation with the idea that it was much more complicated than I originally thought it would be.
nox771
    • rewiredgear
« Reply #8 on: November 02, 2008, 02:18:23 pm »
You know I'm not certain it's entirely over the head of someone new to it, for some reason when I go about these things I always end up taking the hardest route possible.  For me I look at it and I would go the micro route, but look at what this guy did: http://forum.lcdinfo.com/viewtopic.php?t=2490
He took a $20 LCD, a $60 controller, plugged it into myLCD (http://sourceforge.net/projects/mylcd/), and got video working on it.  To be certain he had to have a good level of understanding of what he was doing, and he did some custom coding, but it's much easier than the route I would have gone.  I've seriously got to learn to make better use of off-the-shelf bits and pieces...
clickhea
« Reply #9 on: November 02, 2008, 02:27:04 pm »
well thats pretty cool, but yeah iam just not gonna bother thank you guys ;)
