Author Topic: u360 1 button not working  (Read 819 times)
Martijn
  • Akira!
    • ModMyBox
« on: October 30, 2008, 01:54:51 pm »
i hooked up 2 u360 with wireing harnass
all buttons work for player 1
and for ID2 player 2 all buttons work exept button 5
the green wire.
i checked the microswitch and replaced it, and also the green wire is good till the u360 motherboard pin, i tested with a multimeter.
what could be wrong?
Ginsu Victim
  • Comanche, OK -- USA
Re: u360 1 button not working
« Reply #1 on: October 30, 2008, 02:04:35 pm »
Have you touched the wires together without running through a switch? Does it show the button working?
Martijn
  • Akira!
    • ModMyBox
« Reply #2 on: October 30, 2008, 02:38:55 pm »
tried that
connected wires on the mainboard from green point to gnd
Ginsu Victim
« Reply #3 on: October 30, 2008, 02:41:15 pm »
and did it register at all?
Martijn
  • Akira!
    • ModMyBox
« Reply #4 on: October 30, 2008, 02:45:16 pm »
nope, dead
i flashed from 2.3 to 2.4
still same problem
i think its broken :(
how is this possible..
Martijn
  • Akira!
    • ModMyBox
« Reply #5 on: October 30, 2008, 02:50:12 pm »
ok the track on the pcboard is broken. its not connected to the u360 IC
so no connection from u360 IC to pin green wire.
good thing i can solder this :)
Martijn
  • Akira!
    • ModMyBox
« Reply #6 on: October 30, 2008, 02:57:00 pm »
soldered it, and its working again..
pfew.. saved my trouble of shipping etc..
