Author Topic: What size drill bit do you use for 5mm leds?  (Read 34989 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: October 26, 2008, 06:30:57 pm »
I was going to drill holes for a single led in the bottom of some Happ Transluscent buttons and was wondering what size standard drill bit works best.  Thanks
Knievel
    • Knievel Kustoms
Re: What size drill bit do you use for 5mm leds?
« Reply #1 on: October 26, 2008, 10:36:52 pm »
3/16" is what you want.
Blanka
« Reply #2 on: October 27, 2008, 02:05:30 am »
Guess buying a 5mm bit is the easiest. Even in the U-S and A. 3/16 seems a little toit to me.
Franco B
« Reply #3 on: October 27, 2008, 05:58:36 am »
Its not a standard size but 4.9mm works for me :)
Popcorrin
« Reply #4 on: October 27, 2008, 09:17:40 am »
I tried 3/16 but it was too small.  I don't know if I can get my hands on anything metric.  Maybe I'll see if I can get my hands on a 13/64 and give it a shot.
2600
« Reply #5 on: October 27, 2008, 09:27:33 am »
It's a drill vs. plastic.  Just wiggle the drill around a bit to enlarge the hole a little.
Popcorrin
« Reply #6 on: October 27, 2008, 12:13:47 pm »
I know but I will be drilling out quite a few of them and if I could get the right size it would save me the hassle.
Knievel
    • Knievel Kustoms
« Reply #7 on: October 27, 2008, 12:48:37 pm »
Really? I've been using a 3/16" since day one, and I've done piles of LED holes.
5mm is a standard LED, right?
2600
« Reply #8 on: October 27, 2008, 02:44:41 pm »
Come on guys basic math.
5mm ~= 0.197 inches
3/16" = 0.1875 inches
So a 3/16" drill bit is slightly too small, 1/4" is way too big.  Just work the drill around one swipe for each button.
Franco B
« Reply #9 on: October 27, 2008, 02:55:13 pm »
Or you could just buy a drill to suit your LEDs. Perfect hole every time. My LEDs slide into the hole and then just pinch when the shoulder meets the hole.
Every 5mm LED I have had has been 4.9mm - 4.95mm to allow for clearance in a 5mm hole.
Here is a 4.9mm drill on UK ebay, £1.75 + 75p, im sure you US guys must be able to get one for a similar price [Linky]
Cornchip
  • Last login:December 27, 2023, 10:23:11 am
  • Thinking up more crap....
« Reply #10 on: October 27, 2008, 05:26:52 pm »
  Even better...use a number drill. Plenty of choices under 5mm to try.   ;)
Franco B
« Reply #11 on: October 27, 2008, 05:58:49 pm »
Good thinking Cornchip.
I had a little search and you can buy number drills even cheaper in the UK than that ebay link I linked. Check out [this] site. Number drills 9-13 (the most usefull in this application) are £0.81 including VAT+p&p
Kevin Mullins
    • Me on Myspace
« Reply #12 on: October 27, 2008, 06:06:50 pm »
#9
3/16" would work fine too I'm sure, especially if drilling by hand.... you won't have a perfect hole guaranteed.
Jeez, take a relatively close but undersized drill bit and try one.
Zebidee
  • Trade Count: (+9)
  • Online Online
  • Last login:Today at 12:51:56 am
« Reply #13 on: October 28, 2008, 02:42:01 am »
I always just use a 5mm bit, and when I paint the panel the paint takes up the extras fraction of a millimetre to make a snug fit for the LED.
Popcorrin
« Reply #14 on: October 31, 2008, 06:40:19 pm »
Well, I figured out what the problem was.  I got some different 5mm leds and tried them on  3/16" holes and they worked just fine.  I guess the first batch of 5mm leds I got were actually slightly larger than 5mm.   Strange.  :dunno
