Main > Main Forum
A few general MAME queries by a relative Noob.
Pages: << < (4/4)
DaveMMR:
Thanks - I'll give it a shot during my next update.  Maybe I can get all my games in one MAME.
Turnarcades:
--- Quote from: dailygeek on October 23, 2008, 12:31:44 pm ---
--- Quote from: Turnarcades on October 23, 2008, 10:57:20 am ---http://forum.arcadecontrols.com/index.php?topic=85859.0
See this and my billion other answers recently. Seems like everyone is asking this question at the moment.
You see I clearly meet that second spec, yet if i switch between a couple of games, or play for 5-10 mins, I start getting slowdown, frameskip and soundstutter?
I'm guessing its the RAM (or lack of) it's a pretty basic fresh xp install so there isn't much else going on.  I was using maximus arcade but i'm getting the same thing through the native mame menu too.
See this thread for an answer to that:
http://forum.arcadecontrols.com/index.php?topic=85929.0
cmoses:
--- Quote from: DeLuSioNal29 on October 23, 2008, 06:25:07 pm ---My P4 1.7ghz was able to run Donkey Kong in .119 of MAME just fine once I cut the sample rate for sounds in half.
You have to edit your mame.ini file (If you don't have one, type mame -cc at the command prompt to make one).
It defaults to:
--- Code: ---# CORE SOUND OPTIONS
sound                   1
samplerate              48000
samples                 1
volume                  0
--- End code ---
Change it to:
sound                   1
samplerate              24000
samples                 1
volume                  0
--- End code ---
That will speed everything up, without having to skip frames.
Tiny XP will help a lot too.
Can you elaborate a little on what that change does?  Not sure what samplerate is.  Would this be helpful for anyone running MAME or just in this case with the smaller amount of RAM.
HaRuMaN:
The higher your sample rate, the better quality sound you will have.
u_rebelscum:
--- Quote from: cmoses on October 24, 2008, 11:56:01 am ---Can you elaborate a little on what that change does?  Not sure what samplerate is.  Would this be helpful for anyone running MAME or just in this case with the smaller amount of RAM.
Samplerate: times per second the sound is sampled, or in mame's case, emulated.  If the CPU is just barely not able to emulate the sound cleanly, reducing the samplerate might free up the CPU enough to clean up the sound.
It's not a memory thing (AFA mame goes).   (The mame docs/config.txt file talks about this a little.)
Pages: << < (4/4)
Go to full version
