Author Topic: best stick for fighting games?  (Read 2699 times)
smike13
  • Last login:October 24, 2008, 04:47:40 pm
« on: October 21, 2008, 05:53:56 pm »
hey, everyone i am new at this. i plane on putting an arcade together mainly for fighting games and was wondering what everyone thought was the best joystick for this.  thanks
Nemss316
  • Last login:April 28, 2010, 10:30:00 am
Re: best stick for fighting games?
« Reply #1 on: October 21, 2008, 05:56:08 pm »
I ordered the MagStick Plus from Ultimarc. They have gotten great reviews as a stick for fighting fans, as well as fans of other genres. I haven't received them yet, so I can't give  a hands on impression, but it might give you something to go on.
Ummon
  • Trade Count: (+13)
« Reply #2 on: October 21, 2008, 07:25:42 pm »
Seems about once a month this topic comes up, I think with the same title so you'll likely find a lot in an easy search.
Yo. Chocolate.
Stephen Hawking
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #3 on: October 21, 2008, 07:31:02 pm »
I dunno I seem to hear alot of people say these sticks work great in 4way mode, but are lacking in 8way mode which is what you would be using for fighters/.
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« Reply #4 on: October 21, 2008, 07:48:49 pm »
People seem to like the U360s with the long shaft, stiff spring and resrictor plate. DIRTY!  :censored:
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
DaveMMR
    • TeeVee Games
« Reply #5 on: October 21, 2008, 07:57:22 pm »
Hey!  The restrictor plate is a perfectly cromulent marital aid.
As only a casual player of the fighting games, the U360's have served me well.  You may want to add an octagon restrictor with that if you go that route.
nickynooch
  • Last login:August 29, 2020, 02:54:00 am
« Reply #6 on: October 21, 2008, 08:02:01 pm »
ditto.
Todd H
  • Last login:February 17, 2024, 12:58:49 pm
  • It's Gameday!
« Reply #7 on: October 21, 2008, 09:03:24 pm »
Havok
  • Trade Count: (+17)
« Reply #8 on: October 21, 2008, 09:14:33 pm »
Perfect360.
http://www.happcontrols.com/joysticks/50608300.htm
+1
The U360 even with the heavier spring is too soft, too short and all around wimpy when it comes to fighters. However, great all around stick if you are trying to keep the number of sticks to a minimum.
borals
  • Last login:March 07, 2020, 05:51:14 am
« Reply #9 on: October 22, 2008, 12:32:08 am »
I use the Sanwa's for fighters as they are used in most Japanese fighting cabs.
Highly recommend them over the Happs, purley for the fact they seem easier to use for special moves etc. The "sweet spot" just seems easier to find.
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« Reply #10 on: October 22, 2008, 12:39:56 am »
run supers in mine and not one complaint from anyone playing on my cab
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
Bleagh
  • Last login:October 18, 2016, 04:33:25 pm
    • BLEAGH!
« Reply #11 on: October 22, 2008, 02:39:57 am »
For me any stick will work fine as long as I can feel the corners.  A sanwa jlf with an octagonal restrictor is my fav for capcom and snk fighters.  Competitions or similar are the only sticks I will play Mortal Kombats with though.
Find a stick that is comfortable for you.
rusolinio
  • Last login:December 14, 2010, 08:21:22 pm
« Reply #12 on: October 22, 2008, 05:54:42 am »
I bought the magstik plus sticks and like them vey much when i had them installed in my desktop control panel. This changed dramatically when i decided to swap out the worn sticks in my ki2 cab.
 For ki1+2 and any of the mortal kombats they simply dont work. The combos and special moves are almost impossible to pull off as you always hit a corner when you dont want to.
I then made a hybrid stick combo with the original ki sticks and the mag stick base. It made the sticks sit a little higher, but was a lot easier to pull off combos and specials as the extra length made it easier for me to hit the corners. Sadly, i got frustrated with the slightly sloppy feel my hybrid combo gave me, and opted for the original happ competitions instead.
smike13
« Reply #13 on: October 22, 2008, 12:00:14 pm »
hey everyone, thanks for your input. i am still undecided, but i definitly narrowed it down a bit. thanks a bunch everyone.
smike13
« Reply #14 on: October 22, 2008, 12:04:33 pm »
i just checked out the sanwas what does everyone think of the JLW? and Bleagh why do you pefer the jlf over it?
fjl
  • Pixels Rule!
« Reply #15 on: October 22, 2008, 02:09:41 pm »
JLF is the only one that supports the 8 way octagonal restrictor. I have a JLW and it comes with a built in 8 way that can be switched to a 4 way restrictor. It works but I preffer the octogonal for fighting games.
Jack Burton
  • Last login:August 26, 2023, 11:32:31 pm
« Reply #16 on: October 22, 2008, 04:12:14 pm »
Japanese Sanwa JLF or Seimitsu LS series are considered the golden standard in the fighting game community.  Also IL Competition and Happ/Wico Perfect 360 are the top "american" style sticks and are preferred for a few games. 99% of competitive fighting gamers use one of those models.
What fighting game do you want to play on your cab the most?
« Last Edit: October 22, 2008, 04:13:59 pm by Jack Burton »
Flake
  • Last login:December 04, 2023, 03:02:46 pm
  • I am Evil Homer....I am Evil Homer....
« Reply #17 on: October 22, 2008, 05:01:09 pm »
I have two happ comps in my panel and while I think they play OK for fighting games my future brother-in-law, who is a MK3 nut, has a tough time getting used to them.  It is hard for him to pull off the "finish him" moves.  He is pretty damn good at that game too so I dont think its his inability to hit the right sequence.  FWIW.
smike13
« Reply #18 on: October 22, 2008, 05:04:03 pm »
the fighting games i mostly would play are street fighter II and Marvel Vs Capcom. games like that.
Jack Burton
« Reply #19 on: October 23, 2008, 12:17:58 pm »
If you like SFII better, go with a Sanwa JLF or Seimitus LS.
IF you like Marvel better, go with a Comp or Perfect 360.
But any way you go those sticks are all great for fighting games.
smike13
« Reply #20 on: October 23, 2008, 12:34:27 pm »
thanks, i am gonna go witht he JLF. i think that one will fit me best. thank everyone for your help.
fjl
  • Pixels Rule!
« Reply #21 on: October 24, 2008, 05:00:05 am »
Will you also get the 8 way restrictor?
smike13
« Reply #22 on: October 24, 2008, 04:46:36 pm »
yes, a m gonna get the 8 way restrictor, i was also thinking about adding the bat tops instead of the ball tops.
SNAAKE
  • Trade Count: (+29)
  • Last login:January 11, 2024, 12:21:50 pm
  • my joystick is bigger than your joystick !
« Reply #23 on: October 26, 2008, 03:52:42 am »
its all about persona preference.....
this thread has been done to death but only advice I can give you is that AVOID p360s for any game alltogether. they are quite retarded for fighting games because corners are all messed up and its so stiff  I cant even play on it for more than 10 minutes.
personally I use seimitsu ls32 because its a mix of jap and american. its not TOO sensitive/lose like sanwa and yet its better than any american sticks. I can pretty much do any and all critical combos combos in capcom vs snk 2(things like 1 frame links to supers and custom combos). Ive used many many sticks over the years and seimitsu is the best one for all fighting games imo. and use sanwa buttons. there is  no reason to be using any other buttons. sanwa buttons > ALL other buttons.
