Main > Everything Else
Hi, new member here
<< < (2/2)
Ummon:
--- Quote from: Robbbert on October 13, 2008, 06:10:15 am ---I did, last week.  ;) The current version is 0.127.B
Hello. Do you have a new page? The old one shows .122 as last.
Robbbert:
The problem is that the site is owned and controlled by Tinker, but he isn't around much anymore.
I have no site of my own, all releases are done via the misfitmame forum over at mameworld.
http://www.mameworld.info/ubbthreads/postlist.php?Cat=&Board=misfitmame
danny_galaga:
greetings!
Ummon:
Ah, thanks. Now hopefully someone will make UI version.
Robbbert:
One thing you should know, is that I do not own a cabinet or special controls.
I only use the keyboard. So, if you find that your controller doesn't work properly, or some special setup has issues, you'll know that I have no way to test or fix it.
However, if any of you are knowledgeable on mame coding, and you have a tested, working, solution to some problem, by all means submit it to me.
Navigation
[0] Message Index
[*] Previous page
Go to full version
