Main > Main Forum
trackball lighting
u_rebelscum:
--- Quote from: RandyT on October 14, 2008, 01:46:15 pm ---
--- Quote from: Andymac1990 on October 13, 2008, 05:23:28 pm ---... 3" High-Ball Trackball ... Happ....
... assuming that the High-ball model has a similar light mounting configuration to the others. I'm guessing it's the same base, so it probably does....
Yes, all happs 3" TBs use the same part for the bottom half of the case. The old atari 3" TBs should be exactly same too, but I don't own one of these old TBs, so I can't verify it.
FWIW, the only difference is the top half of the base. Well, okay, and the sensor boards, old arcade green vs new arcade red vs USB.
RandyT:
--- Quote from: u_rebelscum on October 15, 2008, 12:13:04 pm ---Yes, all happs 3" TBs use the same part for the bottom half of the case. The old atari 3" TBs should be exactly same too, but I don't own one of these old TBs, so I can't verify it.
Thanks for the verification! That's good to hear.
FWIW, I also have an old WICO here that looks like the Imperial as far as the lighting is concerned, so that should be covered as well.
I'll try to get some pictures of the new lighting board for those who might be curious.
RandyT
RandyT:
We had a few of these going out today, so I snapped a photo before they were packed up.
The one on the left is the single color version with the mounting hardware inserted in the "Imperial / WICO" position, and the one on the right is the RGB version with the hardware in the "HAPP / Atari" position.
These are using the NOVA light sources, so they are wide angle and each LED is the equivalent of 5 "superbrights". That's the same as 5 and 15 superbright LED's respectively.
RandyT
clickhea:
i seen mine was shipped out today i cant wait to get it
i'll take some pics when i have it installed
DrumAnBass:
Nice Randy! How much?
