Software Support > DOS/WinCab
Why Multiple Covers?
<< < (6/6)
FrizzleFried:
I'll try that.
FrizzleFried:
--- Quote from: Dermbrian on October 20, 2008, 07:00:20 pm ---I wonder if your issue might be fixed by using mp3tag to display the tags and then save them again, using the option I discuss in this thread:
ID3V2.3 Mp3Tag set to ISO-8859-1 cures my bad tags
Brian
I have one thing to say...
YOU ARE THE MAN!!!!!!!!!!!!!!!!!!!!
I changed all tags to ISO-8859-1 and sure as shiznit... it cleaned up 95% of the files!
There are a few that are still being classified as singles when they aren't,  but it looks like only about an hours worth of work instead of dozens of hours!
Chris,  you're going to want to mention this somewhere I do think.
Again,  thank you Dermbrian!!!!!
Space Fractal:
:-). The otherway to convert Unicode to AscII, so it dosent show wrong. In some files it might still require Unicode, if they use other ISO charset, since I wont convert mine, so I can test until the bug is fixed.
About the singles it can been very defficent bug nothing with the unicode to due.
FrizzleFried:
To be clear,  converting fixed the issue.  The only problems I have now are with tags that need fixing.
Thanks again!
Chris:
I think I have fixed this issue; the fix will be in 3.2.1.
Navigation
[0] Message Index
[*] Previous page
Go to full version
