Author Topic: ATI rage Card  (Read 1601 times)
Dillsta
  • Last login:August 15, 2009, 02:35:05 am
ATI rage Card
« on: October 04, 2008, 02:55:24 am »
At the moment i have a p3 800mhz, 256mb sdram and onboard graphics and sound. Most of my mame games run ok but the 1v1 fighters are really bad and slow. I was wondering if i got a ATI Rage 128 Pro 32mb, would it speed it up to a reasonable level?
Thanks Dylan
gonzo90017
Re: ATI rage Card
« Reply #1 on: October 04, 2008, 01:45:22 pm »
What fighters are you talking about?
MrMojoZ
  • Last login:June 25, 2009, 11:34:56 pm
Re: ATI rage Card
« Reply #2 on: October 04, 2008, 03:31:48 pm »
I'd say CPU is holding you back more than anything unless your emulator just isn't compatible with your onboard video.
Re: ATI rage Card
« Reply #3 on: October 04, 2008, 04:49:28 pm »
That's not a huge graphics card upgrade, most likely.  Your CPU and RAM are the limiting factors here.
Dillsta
Re: ATI rage Card
« Reply #4 on: October 05, 2008, 02:57:54 am »
I'm trying to play games like street fighter. but the games that run slow don't work when i have directx turned on in the mame config. I just get an arror that says
Error creating dirextX7 device: 887602eb
Video emulation was not started.
Thats why i think a graphics card might help!
but when directX is turned on  i get a framerate of 5-10fps. which is shocking. :banghead:
Does this help at all?
vidmouse
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
Re: ATI rage Card
« Reply #5 on: October 05, 2008, 08:08:26 am »
What version of MAME are you using?
You may have better luck with older versions
SirPeale
  • Green Mountain Man
Re: ATI rage Card
« Reply #6 on: October 05, 2008, 08:47:53 am »
Agreed.  This and your CPU are limiting factors.  Video card matters little.  How it's used, OTOH, does matter.
gonzo90017
Re: ATI rage Card
« Reply #7 on: October 05, 2008, 01:18:44 pm »
Just use Nebula. It runs all CPS2 games which includes street fighter full speed on my 400mhz Celeron 128mb ram.
Dillsta
Re: ATI rage Card
« Reply #8 on: October 06, 2008, 02:24:43 am »
I have used Multiple Versions of mame from 0.66 up to .104 with all the same results. the only problem with the cpu is that i have an old mother board so it is hard to get a better p4 cpu. But i think i need a graphics card to fix the directX error. What do you guys think?
Thanks Dylan
MrMojoZ
Re: ATI rage Card
« Reply #9 on: October 07, 2008, 05:05:27 pm »
Oh I'd say you would have a VERY hard time putting a P4 on your P3 motherboard....
Jack Burton
  • Last login:August 26, 2023, 11:32:31 pm
Re: ATI rage Card
« Reply #10 on: October 07, 2008, 08:30:28 pm »
Try these emulators for 2d fighters in this order
Final Burn Evolution
Nebula
Final Burn
Kawaks
NeoRageX
the last two ran 100% on my PII 350 MHZ with 128MB of ram.
Dillsta
Re: ATI rage Card
« Reply #11 on: October 08, 2008, 03:04:38 am »
Thanks Jack for them but none of them seem to run through mala!!!
Does any one know of any that will???
