Main > Everything Else
Sleep Apnea
protokatie:
--- Quote from: pinballjim on October 02, 2008, 07:09:27 pm ---Is there anyone on this forum that doesn't have some kind of exotic disease?
The only disease I don't have is Hypochondria.
Xiaou2:
An old Post I made about Breathing and Meditation:
(try it as you read it)
In this world, we are always so busy and our minds and
souls are filled... sometimes with worries and negativity.
We may feel a bit unstable, lost, troubled, disconnected.
By doing specialized meditations, we kinda get reconnected
to a higher power. In time, it may feel like you are
literally floating on air, even when you are not meditating!
You will gain a quietness within your mind that never
existed before... and then are able to think more calmly and clearly.
Be more sensitive to things around you. Maybe even get
intuitive thoughts, visions..etc. You will feel much more
clam, relaxed, peaceful, and Happy.
However, to get the benefits.. it will take some
efforts. And at first, you may want to give up
before the magic happens. You may at first be board,
or restless... and think its a big waste of time. I
assure you, it will be worth it to stick with it.
Even if you do this for only a month or so.. it can be a
life changing event. And even if you hadnt meditated for
years (afterwards).. you still will carry around with you
many benefits.. as they are forever with you. (just maybe
not quite as strong as if you continually are active in it)
I know how when most people read the word Meditate.. they
are already thinking.. this isnt for me. I dont have time.
I cant imagine sitting there (appearing to) doing nothing.
Trust me, and take a chance. I promise results that will
make you feel so much better... and you will be so glad
you took the time and efforts to do it. The TV show
can wait
Ok, this will seem a bit long in words.. but its actually quite
simple to do, so dont fret Here goes...
--- The Breath ---
The first thing that has to be learned is the Meditative breath.
Sure, you could do this without it... but it will gain you
much greater rewards with it. Its a bit tricky to do, and feels
awkward and odd at first. Will take about 2-3 months to get to
the point where it will feel un-noticeable and comfortable.
(it may even end up toning your tummy too
There are 4 major parts to the Breath... and a delay time can
be inserted into any or all sections of this as you desire.
1) Fill the Lungs
2) Fill the Dan Tian (Ab/Stomach Area)
3) Exhale the Dan Tian
4) Exhale the Lungs
What the Dan Tian?
When many people breath... they only breath shallow breaths..
never using their full capacity. We not only wish to breath
in and hold more air... but to control the airflow with our
internal muscles very well. The Dan Tian is the lower section
just below the belly button.
Lets try the Dan Tian breath Only:
1) Press both your fist deep into your belly button area,
and hold then there with firm pressure.
2) Now, try to Breath air through you NOSE, into that belly area,
and Force the Fists to be pushed outwards. While you can do this
with muscle alone... with breath makes it very different.
(try not to fill the upper lungs when doing this. Only fill the Dan Tian)
3) Once full and fist have been pushed out... then SLOWLY push inwards
with the fist again while exhaling out through your MOUTH SLOWLY.
Try this a few times... then try without using the fists a few times.
This is the 1st step. Now try the Full Breath:
1) Place one hand on your chest, and one on your Dan Tian
2) Breath in slowly through the Nose, filling the top Lungs ONLY,
making sure NOT to fill the Dan Tian area. If you start to
fill it, you will notice your hand moving outwards from the
Expansion. Try to stop it, and continue to fill the lungs
only until they are filled as much as you can stand. You should
be able to feel the lungs expand as your hand moves out with
them.
(You now see just how tricky it is to control each section separately,
because you naturally just use them both at the same time,
in shallower breaths)
3) Now fill the Dan Tian (belly area) Slowly, until its full. Now
ALL of your lungs should be completely full to its capacity with
air. You want it so full, that it almost hurts. That will help
to stretch out your lungs, and give them more capacity later.
4) Exhale through your Mouth, ONLY the Dan Tian... and NOT the lungs.
We are doing things in reverse now. At this point you may
accidentally breath some of the lungs air out. Try to stop it..
and keep working with the Dan Tian only.
5) Now that the Dan Tian is empty, keep it held inwards while
you breath out the Lungs. You should Push fairly good so that there
is no air left in the lungs. This push will help to make sure there
is no air, as well as strengthening the internal muscles. You
should have felt the hand move inwards while you exhaled.
6) Repeat the process over and over for at least 5 minutes. Repeat
this drill maybe once or twice a day for maybe a weeks time.
By that time, you should have gained much better control. Still,
It may be a little sloppy. It will take a while to perfect this
into feeling Natural.
A NOTE: I use a special method to Breath out through the mouth:
1) Open the mouth slightly and let your jaw hang loosely.
2) Pretend you got a Novocaine shot from the Dentist.. and your jaw and
mouth have no feeling or control. They as so loose. If you
shake your head... they will flap around. heh
3) Exhale and make an extended "Huhhhhhh-OHh" sound. The easiest way
to test this is to place your hand in front of your mouth,
and then use the 'Huhh' to create moisture on your palm. Its
the type of breath you would use to write letters on a glass
window... or to check your own breath. Just a little deeper,
looser, and slower... with a slight 'o' sound in there. However, the Ohh sound
should be more like a Wispered Ohh that floats on the winds, and not a fully
defined and pronounced "O" sound. Its a wind/breath sound.. and not really so much
vocal. Its more to do with the shape of the mouth and throat as the air exits.
At first, your breath will be hardly audible. But in a few months,
Your breath exhales should be pretty loud, deep, and very long. Give it time. Youll be
amazed at the difference!
--- Beginner Meditation + Breath ---
1) Find a quiet place, and a good time when you wont get interrupted.
Usually near Bed time at Night is best.. tho make sure you arnt
so tired that you will sleep. Wear loose comfy clothing.
2) Sit comfy with legs crossed, eyes closes, and back of palms gently
lying gently on your knees. Keep your back fairly straight, yet relaxed.
3) Slowly breath into nose filling lungs only, and when full, fill the
Dan Tian slowly. Count to 5 in your mind, as you are filling up.
4) With no Air.. Hold your breath for a 5 seconds. Remember to keep the
Dan tian inwards untill you breath in.
5) Exhale out your mouth Slowly, Dan Tian first... then lungs. Count
to 5 as you are exhaling.
6) With no air, Hold 5 seconds... then repeat the process for at least
6 minutes... or until you feel satisfied. No less then 5 minutes,
or you really arnt going to get much if at all out of this.
During this, all you should focus on is the control and flow of the
breath.. and the counting. I posted a number of '5'... but you can
change that to a time that is best for you. If 5 is too long and you
cant maintain your breath for so long without Gasping for air... then
you want to lower that number. If its so short that you arnt using your
lungs full capacity... then you want to raise that number.
Over time, you will see a dramatic change in your ability. You will
get more capacity, and breath longer deeper breaths with ease.
--- Advanced Meditation ---
Now, the only difference here... is that instead of Focusing
only on your internal breath and counting.. is that we will
now use our mind to visualize certain things.
1) As you breath in... Imagine in your mind.. that you are
breathing in a cloud of bright white gas mist. The cloud is
warm and healing.. and may tingle.
2) As its 'filling into you' imagine the feel of the healing
warmth travel all thru your lungs, chest, Spine, and it will also
flow all thru your body from center outwards. It will travel down
your legs to your feet.. Down your arms, up the neck, and even
fill the head. See this happening, and try to feel it as you
see it in your mind. (it may take like 3+ times before you actually start
to feel the things you are visualizing. Weak at first.. and stronger later on)
3) As you hold your breath.. you have even more time to
feel the warm healing powers cycle through your system.
4) Now, as you exhale.. you want to imagine that the
energy has absorbed all your negativity and bad energy...
and you now are going to expel it out of your body.
See it travel from your feet up your legs, your head and
arms and all the rest.. and out of your mouth. You should
imagine it coming out as a dark color like black or brown.
5) Repeat this with each breath during the meditation. At
first.. you may not feel anything different at all. But after
a few sessions, you should be actually feeling the healing
energy radiate and flowing through you. Its an Amazing
feeling!
After you have done a few meditations, you should start
feeling so much more relaxed, balanced and centered...
Its kinda like a shower for the soul. Wiping away
all your tension, worries, fears, doubts, and other
negativity.
--- Caution ----
Now, Ive never ever had any complications.. but, I have to put this
in 'just in case'. I take no responsibility for any problems
that these exercises may cause upon you. Do these at your own risk.
SithMaster:
I think we have one of everything. The collection is complete.
protokatie:
--- Quote from: SithMaster on October 02, 2008, 10:06:52 pm ---
It doesnt run at full-speed on MAME V.89+. And if you try to run our collections on earlier versions, you will encounter bugs.
But, it is still only important that we have the full collection.
Loafmeister:
Xiaou2, I got that and I know some stuff like that is real. But we are talking about a diagnosed sleep apnea patient with a real physical issue thus why IN THAT CASE I don't think meditation can help. But to each is own of course.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
