Main > Main Forum
How much does 3/4" MDF cost per square foot?
Pages: << < (2/2)
AgniTheSane:
--- Quote from: The cranky hermit on June 13, 2003, 03:25:28 pm ---Any reason I can't cut the MDF? I'm going to be working on this project with a relative, who owns several woodworking tools.
I am sure it is fine (although I would wear a mask). You are  making a few cuts, but the HD people cut a lot of wood every day. It was only an issue with me because getting a 4x8 sheet of anything into my little jeep is just not possible unless I get it cut first.
The cranky hermit:
What would you use to cut it? A circular blade?
bionicbadger:
You can cut it with with pretty much anything.  During my project I used a table saw, skil saw, jig saw and router, doing different cuts on the MDF.  Use a table saw where you can for the straightest cuts.
If you are going to build the whole cabinet out of MDF I would look for the "lightweight" MDF, it costs a bit more, but weighs less, and when you use 2 1/2 sheets for your cabinet, it gets pretty heavy.
The cranky hermit:
I'm just building the CP. Maybe I'll build a cabinet someday, but right now I don't have the money or time.
AgniTheSane:
I cut the pieces for my cabinet out yesterday (my project is just starting) and I used a skil saw for most of the straight cuts, and a jigsaw in the places that a skil saw just would not go.
A bought a long metal guide at HD to help with the straight cuts. It really helped with the skil saw, but I found I did better freehand with the jig saw.
Pages: << < (2/2)
Go to full version
