Main > Software Forum
Favorite Front End
<< < (21/87) > >>
retrometro:
I tried mamewah and HS.  MALA is easy and flexible.
liquid8:
As much as I enjoy using (and looking) at Hyperspin, I currently still give my vote to Mamewah. Even though Mamewah still is a bit difficult to configure, it is comfortable to me and I like the easy way of setting up groups, platforms, and lists... including adding games to lists right from the frontend.. which is important to me.
As we all know, though, it depends on what your using it for, and as Minwah pointed out, your setup.
If you are going for LEDs or Cocktail setups, I can't imagine using anything but Mala. If I was using MCE for my media center, I would go with GameEx, as it integrates nicely. If you want the most customizable frontend ever (with the "cool" factor), use Emulaxian/3D Arcade. If you want a fairly simple setup with eye candy, go with Hyperspin.
I am finally (hopefully) starting to work out my own setup, and I'll be playing with many of these again, or for the first time as sort of a re-evaluation. I am in and out of the emu scene, and love coming to see the improvements and new features in ALL frontends... so keep it up, guys! :)
drewbagel423:
I love the way Maximus Arcade looks and operates, but now that I've got Hyperspin successfully launching PC games for me (the only one that CAN out of the 4-5 I've tried!) I'd hafta say that's my favorite.  But I am having trouble with it regarding some emulators and the fact that it doesn't close them.  Instead I'm told I have to set my emulators to have the same exit key (if the emu supports it) or map a button for the exit key for the specific emu.
It comes with this Hyperlaunch thing which supposedly does the job but I can't find any support documentation on it.  If someone could combine MA and HS it would be the ultimate front-end!
EDIT:  Ok so the guys over there at HS have been really helpful, and I'm getting closer to having a front-end that does EXACTLY what I want it to.  I'm definitely leaning more towards HS at this point.
boomstick:
Only FE I have used so far is MaLa, love it and dont see any need to change at present
geocab:
Right now I'm using MAMEUI as it is the only FE I knew anything about until I found this forum a week or two ago.  I want to try the others eventually to see if I find one I like better, but as I'm in the earliest stages of cabinet planning, I don't have a real need to change from the keyboard/mouse friendly MAMEUI.  For instance, I briefly tried Hyperspin and although it was definitely flashier, I can find the game I want with the mouse much quicker than scrolling though a wheel.  I'm not knocking Hyperspin, obviously when I want to control my FE from my arcade control panel (when I have one) MAMEUI probably will no longer be the right choice for me.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
