Author Topic: Has anyone tried using a white acrylic sheet behind a marquee?  (Read 891 times)
ivwshane
  • Last login:December 24, 2022, 09:35:21 pm
    • My first mame cab! (WIP)
« on: September 22, 2008, 11:03:51 pm »
I was thinking of using a piece of white acrylic behind the marquee graphic to help diffuse the light and give it a more consistent look.
Has anyone tried this? What were the results?
The only negative I could see is that it might wash out the marquee graphic.
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
Re: Has anyone tried using a white acrylic sheet behind a marquee?
« Reply #1 on: September 23, 2008, 02:55:49 am »
I use a white acrylic diffuser behind my marquee. It does create a more even spread of light. I used Cold Cathode tubes for my marquee. 2 of them approx 8 cm apart. You cant see the individual tubes just a constant illumination. Didn't have any problem washing out the graphics. It's not nearly as bright as a fluresent though. Heres a vid of it in action.
[youtube]http://www.youtube.com/watch?v=H0c9m6slbH0[/youtube]
When pixelated clipart just wont do, just call for Betty
« Reply #2 on: September 23, 2008, 09:23:58 am »
You can use a diffuser panel from a fluorescent light... easy to cut to size and only a few bucks at your big box hardware store.
  • Last login:October 20, 2023, 11:39:06 pm
« Reply #3 on: September 23, 2008, 12:28:58 pm »
Whoops.. second time I did that this week.  Wrong topic.  Sorry all.   ** Post removed **
« Last Edit: September 23, 2008, 01:08:52 pm by DeLuSioNal29 »
polaris
  • veni vidi congai
« Reply #4 on: September 23, 2008, 12:54:23 pm »
theres also theatrical lighting filters that you can use but chads suggestion would be cheaper
meany
  • Last login:May 01, 2019, 02:12:23 pm
  • Atomic batteries to power, turbines to speed....
« Reply #5 on: September 23, 2008, 12:54:52 pm »
I used a black transparency behind mine with cut outs to make certain areas more bright.  Look at the text and the eyes.  Those areas pop more.  Those areas were left clear and the rest is dark.
« Reply #6 on: September 23, 2008, 01:55:17 pm »
That looks pretty good.   :cheers:
