Author Topic: U360s & Joy2Key  (Read 1223 times)
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
U360s & Joy2Key
« on: September 18, 2008, 02:09:14 pm »
I soon will be using U360s and am trying to understand how well it will work with Game Ex and my other Emu's. With my current setup, I have an X-Arcade that outputs key presses for button presses etc. but it is my understanding that the U360s do not work this way. I downloaded joy2key just to get idea of what it was but I see no exe file... Can anyone explain how this works in general?
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
Ginsu Victim
  • Comanche, OK -- USA
Re: U360s & Joy2Key
« Reply #1 on: September 18, 2008, 02:11:24 pm »
joy2key simply translates gamepad output to key presses. If a program doesn't support a gamepad, joy2key is a great option. (I have U360s and have not needed joy2key, though)
DaveStall
  • Last login:February 19, 2021, 05:56:25 am
Re: U360s & Joy2Key
« Reply #2 on: September 18, 2008, 02:27:03 pm »
I am using XPAdder rather than joy2key but I assume it works pretty much the same way.  You simply have the program assign a keystroke to a particular direction of the joystick.  I found that I needed to use such a utility with my frontend (GameEx) if I wanted to be able to use joytick+button presses simultaneously, such the the alpha paging feature of GameEx.  If you are having problems with joy2key, give XPAdder a try.  It has a nice graphical UI, support for multiple profiles, and many other useful features.
Dave
Visitor Q
  • The Saw Is Family
Re: U360s & Joy2Key
« Reply #3 on: September 18, 2008, 02:32:13 pm »
I will look into XPAdder, thank you.
I will also be using Game Ex as well as HyperSpin from time to time. I plan on using NullDC as well which I don't think supports joysticks as of yet...???
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
Re: U360s & Joy2Key
« Reply #4 on: September 18, 2008, 04:36:47 pm »
This probably isn't what you were looking for, but still might be useful for you.
There is a plugin for gameex that works with the u360 controller.  Its basically changes the mapping of the u360 to 8 way 4 way or whatever depending on the game.  There is one or two different pluggins listed on the forum.  I set mine up well over a year ago so don't remember to many details about the setup, but it works very well.  When I get home I'll try to find some more info.
stephenp1983
Re: U360s & Joy2Key
« Reply #5 on: September 18, 2008, 06:06:04 pm »
Yeah I found the one I used in the plugin thread on the gamex forum.  Its the second one by Oqqalz.  I never could get the one by cupid to work right.
http://www.gameex.info/forums/index.php?showtopic=2704
DaveStall
Re: U360s & Joy2Key
« Reply #6 on: September 18, 2008, 09:34:11 pm »
The Ultrastick plugin is part of the GameEx installation now.  All you need to do is enable it via the plugin manager.
Dave
stephenp1983
Re: U360s & Joy2Key
« Reply #7 on: September 19, 2008, 06:37:40 am »
awesome thanks for the info dave I had no clue I haven't updated mine in about 6 months
