Main > Main Forum
Painting a Coin Door. Tutorial?
Frostillicus:
I would think powder-coating would be a little overkill on a matte finish old coin-door. I used about 2 coats of black rustoleum on mine, and it looks great.
SirPeale:
Powder coating a coin door should run between $8-$20, depending on the shop. You'll get a flawless, durable finish.
More expensive than some sandpaper and some spray paint? Yes. But the results are well worth it. And really, it's a drop in the barrel when you consider what you pay for the rest of your cabinet.
BillyJack:
If that's all it costs then YES HELL YES it would be worth it. No moron friends would be able to mess up a powdercoat job. I figured about 50 bones for a job like that, but then I've never done it before.
BillyJack
Les:
--- Quote from: Peale on June 13, 2003, 08:05:31 am ---it's a drop in the barrel when you consider what you pay for the rest of your cabinet.
Yeah but all those drops quikly start to fill the barrel!
Hoagie_one:
--- Quote from: Les on June 13, 2003, 09:33:17 am ---
I concur
