Author Topic: Help Mortal KOmbat 1 block stopped working  (Read 1092 times)
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« on: September 14, 2008, 05:46:24 pm »
player 1 block stopped working today. I checked the wires, jamma harness, and replaced chery switch. There is no signal from the button when pressed. I do not know what to do. Please help.
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
  • Last login:Yesterday at 08:24:26 am
Re: Help Mortal KOmbat 1 block stopped working
« Reply #1 on: September 14, 2008, 05:56:49 pm »
what happens when you touch the block wire to the ground wire? I had a similar issue, the jamma pin was loose.
ctozzi
« Reply #2 on: September 14, 2008, 07:56:48 pm »
it's working again, i removed the jamma harness and wiggled the wire around and it works again. the machine is 16 yrs old so I guess i'll be patient with any small issues.
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
ctozzi
« Reply #3 on: September 17, 2008, 12:55:18 pm »
so this keeps on happening it works then stops in the middle of a round i'm frustated and not sure what to do.
I changed the cherry master switch, removed the jamma harness and cleaned it and it still screws up
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
BobA
  • What Me Worry?
« Reply #4 on: September 17, 2008, 07:58:53 pm »
Try cleaning the contacts on the PCB.
ToplessZ
  • Last login:December 08, 2018, 09:55:34 pm
« Reply #5 on: September 17, 2008, 09:34:02 pm »
might be a loose wire connection where it connects to the jamma pin, you might need to repin that wire or at least take some solder and solder it up to the pin to make sure it has a good connection.
ctozzi
« Reply #6 on: September 18, 2008, 12:13:11 pm »
the jamma connector looks fine but in the process of cleaning and pushing pulling the pin broke, so now i need to repin the wire. Does home depot/ lowes carry this  ? In the process of fiddle farting with this another pin broke loose in the jamma harness so now player 1 high kick does not work either. So now i need to put 2 new pins in there. Not a huge deal but I need to find the pins them selves. And I'm not even sure this is the issue either. But it's a hobby and there are always going to be hiccups so I'm not gonna get all flustered
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
ctozzi
« Reply #7 on: September 18, 2008, 09:22:20 pm »
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
ctozzi
« Reply #8 on: September 19, 2008, 06:16:33 pm »
those connectors worked like a charm, i soldered them to the wires and put them in the back of the jamma harness. Works and looks like new !!!!!!!
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
