Author Topic: Wierd usb problem  (Read 847 times)
somunny
  • Last login:September 05, 2018, 02:22:25 pm
  • Is it hot in here?
Wierd usb problem
« on: September 11, 2008, 03:28:04 pm »
I've had a separate powered usb hub in my cabinet for years to handle the inputs from the control panel.   Recently, I decided to purchase a usb expander that plugs into the header on the mobo and fits in one of the rear slots.
After I installed the unit and connected everything back up, I found that the trackball wouldn't work.  All buttong, joys and the spinner worked as they did before but no trackball.
Anyone have an idea as to why?
The usb unit I installed is powered via 5V.
  • Last login:December 13, 2023, 12:03:14 am
Re: Wierd usb problem
« Reply #1 on: September 11, 2008, 04:13:47 pm »
Im taking it that you are using windows..
Did you check device manager, to make sure there is not a conflict?
You may have to go online and download latest usb drivers from Microsoft.
kelemvor
  • Last login:May 13, 2012, 09:40:44 am
« Reply #2 on: September 11, 2008, 04:21:04 pm »
Or try moving it to a different USB port in case something happened to the one you are using.
somunny
« Reply #3 on: September 11, 2008, 07:24:42 pm »
If you mean different headers on the mobo the, yes, I tried that same results.  If you mean moving the trakball to a different usb port, tried that also.  No go.
Yep, Win XP.  I'll check the device manager and do some driver research.  Thanks!
kelemvor
« Reply #4 on: September 11, 2008, 08:24:07 pm »
Take the new thing back out and see if it all goes back to normal...
somunny
« Reply #5 on: September 11, 2008, 08:40:11 pm »
I had to hook it back up as it was initially so I could play!  ;D
The usb expander works with all the other inputs (buttons, joys and spinners) so it seems to be functioning okay with the exception of the trackball.
