Main > Main Forum
Cost of fabricating a metal control panel?
Pages: << < (2/2)
Ummon:
They'll probably be listed under laser cutting or water cutting. Or try fabrication - metal. Certainly online listings will come up from those words.
councilface:
--- Quote from: Ummon on September 11, 2008, 09:19:58 pm ---They'll probably be listed under laser cutting or water cutting. Or try fabrication - metal. Certainly online listings will come up from those words.
Probably throwing "CNC" into the search criteria would help too. Im getting a buddy to do a new panel at my work for me. We arent subcontractors though Im afraid.
grbgemen:
a local friend of my father made me mine.  he cut a sheet of 1/8" steel and bent it with this huge press.  he didnt wanna charge me for it but i gave him $40 anyways.  i drilled the holes myself with a step bit.  step bit was $40 and it was dull after 14 holes.
Ummon:
--- Quote from: grbgemen on September 14, 2008, 02:47:26 pm ---a local friend of my father made me mine.  he cut a sheet of 1/8" steel and bent it with this huge press.  he didnt wanna charge me for it but i gave him $40 anyways.
If he had that gear, he probably had a proper drill press.
grbgemen:
yea he did but he was is always really busy and i did not have the button layout ready.  the plan was to take it home, mark out all the holes and then take it back.  after i got all of it figured out, i tried to contact him for days but never got a hold of em.
ended up buying the bit and doing it myself.
he did have a sweet drill press though.  has like 5 presses all in one.  you can put different bits in each press and just go down the line.
Pages: << < (2/2)
Go to full version
