Main > Everything Else
Hurricane (for real this time)
shmokes:
No no no . . . my previous post was:
--- Quote from: shmokes on September 06, 2008, 01:52:44 am ---Meh . . . what's the worst that could happen? ;D
And if I die in this storm, it most likely means that my cab was completely submerged in seawater. Something tells me you'll never show up to haul the thing out.
Jdurg:
Well it could still change. I mean, these things change direction nearly every single hour. Hannah was supposed to already be hitting where I am (SE, Conecticut) and be out by the end of the day. It changed direction a TINY bit and has slowed down. Thankfully, it doesn't look like it will be horrific but the slight change in direction means that I'll probably be on the eastern side of the storm which is the bad side. Need to look out for the occasional Tornado as that will probably cause more damange than the Tropical Storm itself. I just hope that it doesn't stall and I only get about four inches of rain instead of seven or eight.
ChadTower:
Ike could put you Beyond Thunderdome.
Jdurg:
Well, here in the Northeast I'm no longer worried about Hannah. The storm appears to be rapidly moving and now far more to the northeast than before. There's a very good chance this will be no more severe than a summer thunderstorm for me.
shmokes:
Now it's looking like it'll just miss us. Again. We'll see. :)
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
